How to Change a thermostat on a Dodge Charger - Dodge Charger Forums
post #1 of 11 Old 12-10-2010, 03:29 AM Thread Starter
Gee Dark
Member
Gee Dark's Avatar
Send a message via AIM to Gee Dark
(Thread Starter)
Post How to Change a thermostat on a Dodge Charger
2.7L Engine
1. Disconnect the negative battery cable.
CAUTION
Do not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
2. Drain the cooling system into a suitable container
3. Disconnect the radiator lower hose from thermostat housing.
4. Remove nuts from the heater tube flange studs.
Fig. Thermostat housing (1), bolt (2), nuts (3) and weeping hole (4)-2.7L engine
5. Loosen the starter bolt at heater tube bracket.
6. Pull the heater tube out of thermostat housing and position out of the way.
7. Remove thermostat housing (1), O-ring (2) and thermostat (4).
8. Remove thermostat housing bolts (3).
To install:
1. Thoroughly clean the gasket sealing surfaces.
NOTE
Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
2. Install thermostat and seal (2) into thermostat housing (1).
3. If removed, install the two studs.
4. Lubricate a new heater return tube O-ring with coolant.
5. Position the heater return tube flange over the two studs. Install the 3 retaining nuts and torque to 53 inch lbs. (6 Nm).
6. Tighten the starter bolt to 40 ft. lbs. (54 Nm).
7. Connect the lower radiator hose to thermostat housing. Install the hose clamps.
8. Refill cooling system
9. Connect the negative battery cable. Start and warm the engine. Check for leaks.
3.5L Engine
WARNING
2. Drain the cooling system.
3. Raise and safely support the vehicle.
4. Detach the electrical connectors from the engine oil and power steering pressure switches.
5. Disconnect the radiator and heater hoses from thermostat housing.
6. Remove thermostat housing bolts.
7. Remove the housing, thermostat, and gasket.
NOTE
The OEM thermostat is staked in place at the factory. To ensure proper seating of the replacement thermostat, carefully remove the bulged metal from thermostat housing using a suitable hand held grinder. It is not necessary to re-stake the replacement thermostat into thermostat housing.
Fig. Thermostat housing/coolant inlet (1), thermostat (2) and gasket (3)-3.5L engine
To install:
1. Thoroughly clean the gasket mating surfaces.
2. Position a new gasket on thermostat and housing.
3. Install thermostat housing, gasket and mounting bolts onto block. Tighten attaching bolts to 105 inch lbs. (12 Nm).
4. Install the radiator hose.
5. Install the bypass hose.
6. Connect the negative battery cable.
7. Fill the cooling system. Start and warm the engine. Check for leaks.
5.7L Engines
3. Disconnect the radiator hose from thermostat housing.
NOTE
Thermostat o-ring is part of thermostat and is not serviced separately.
4. Remove thermostat housing mounting bolts, thermostat housing and thermostat.
Fig. Thermostat housing (1), thermostat (2) and retaining bolt (3)-5.7L engine
To install:
1. Clean the mating areas of timing chain cover and thermostat housing (1).
NOTE
Install thermostat with the bleed valve located at the 12 o'clock position.
2. Install thermostat (spring side down) into recessed machined groove on timing chain cover with bleed valve located at the 12 o'clock position.
3. Position thermostat housing on timing chain cover.
4. Install the two housing-to-timing chain cover bolts (3). Tighten bolts to 112 inch lbs. (13 Nm).
WARNING
Thermostat housing must be tightened evenly and thermostat must be centered into recessed groove in timing chain cover. If not, it may result in a cracked thermostat housing, damaged timing chain cover threads or coolant leaks.
5. Attach the lower radiator hose to thermostat housing.
6. Carefully lower the vehicle.
8. Connect the negative battery cable. Start and warm the engine. Check for leaks.
Gee Dark is offline
post #2 of 11 Old 06-15-2011, 02:51 PM
Ddude2
Junior Member
on the 2.7l is it near the engine? or near the radiator on the front end of the car?
Ddude2 is offline
post #3 of 11 Old 06-15-2011, 03:07 PM
EVIL R/T
Senior Member
EVIL R/T's Avatar
why disconnect the battery?
09 R/T Brilliant Black Crystal Pearl R&T
V1 Blendmount hardwired to SAVVY * 3M tint * HELLA Optilux XY fogs/highs * MOPAR CAI * Strut Tower Brace * Stage 2 Coilover Kit * Anti-Sways * T Handle Shifter * Pedal Kit * Hood Struts * Rear Air Diffuser * PCM Cover * Under Hood Light * Glove Box Light * DIABLO 93CAI tune 9r18 * CORSA Xtreme Catback * BND 8.5w-35 QuantumBlue Oil * ACES IV * Gold HP Coolant * BILLET TECHNOLOGY 2nd Anniversary Catch Can * RER 2.404/Gracenotes 4620 *
EVIL R/T is offline
post #4 of 11 Old 06-15-2011, 03:24 PM
Ddude2
Junior Member
hey do you know where the thermostat is located?
Ddude2 is offline
post #5 of 11 Old 06-15-2011, 07:59 PM
rodneyiii
Senior Member
rodneyiii's Avatar
Quote:
Originally Posted by Gee Dark View Post
5.7L Engines
This could get interesting! It's definitely the TOP hose that goes to the T-stat housing.
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
rodneyiii is offline
post #6 of 11 Old 06-16-2011, 07:36 PM
Part Deux
Super Moderator
Part Deux's Avatar
5.7, use the gallon zip lock bag
I've wanted to try a shop vac on the overflow tank while changing the stat.
aka THO.R
Quote:
Originally Posted by 08 Stoned Charger View Post
I have a name for the 3 new mods...............Druken Purple Pirates!!!
Quote:
Originally Posted by Daytona606 View Post
American Muscle, like a pit bull. Big but not large, well defined, explosive power, in it till the end. The cat will give it go and zig and zag, but in the end the pit bull will always catch the cat the outcome is never good for the cat.
Part Deux is offline
post #7 of 11 Old 06-16-2011, 08:09 PM
Binns
Senior Member
Binns's Avatar
and DON'T take off the pressure cap before removing the hose
and put a pan under the car just in case
Binns is offline
post #8 of 11 Old 06-16-2011, 08:11 PM
Binns
Senior Member
Binns's Avatar
it was easy though just the clean up was messy =\
Binns is offline
post #9 of 11 Old 06-17-2011, 04:34 AM
un4givun2
Senior Member
Quote:
That's what I was thinking. I've never worked on a 2.7L, but is there something unique to the 2.7L that requires you to disconnect the radiator hose? Can you not just remove the bolts/nuts from the T-stat housing and pull it loose form the engine without disturbing the hose? It's been my experience that when you remove a hose from the radiator or the engine and put it back on it leaks. Especially with the OEM spring loaded clamps.
Good idea! I may have to try that one since I'm getting ready to install my summer T-stat and change the coolant.
un4givun2 is offline
post #10 of 11 Old 06-19-2011, 12:18 PM
Part Deux
Super Moderator
Part Deux's Avatar
Quote:
Please let me know if it works!
But, if you're changing the fluid anyway, it's really not going to matter The idea behind the shop vac is to create enough of a vacuum to prevent any fluid from running out when the gooseneck is loosened.
Tags
2.7, 3.5, 5.7, dodge charger, thermostat
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
3.5 thermostat change manny1222 V6 Specific Discussion 11 01-10-2011 03:56 PM
2006 Dodge Charger Base Thermostat googalabosh Charger Problems/Assistance 0 04-02-2010 07:35 PM
Should I change thermostat blake General Charger Discussion 2 04-01-2008 10:33 AM
About To Change My Thermostat HemiDad General Charger Discussion 7 08-20-2006 05:20 PM
Thermostat change - early results ... wquiles Performance Discussion/Modifications 32 06-21-2006 05:59 PM
You may post new threads
You may post replies
