Squeeking steering column when cold - Dodge Charger Forums
post #1 of 9 Old 11-16-2010, 06:24 AM Thread Starter
frankiee
Member
(Thread Starter)
When I turn the steering wheel there is a squeeking noise in the column.
I gets wrose the colder it is.
I had it last winter then the summer came with warm weather and the noise went away.
Now that the weather is getting colder the noise is starting to come back when it is cold in the cabin.
Thanks
frankiee is offline
post #2 of 9 Old 11-16-2010, 09:41 AM
stevehemibee
Senior Member
That has happened to me as well.
Superbee #834, Mods, HHP Stage 2 Heads, Cam, and Intake Package... 1/4 PB, 11.45 @ 118......goal achieved!!
stevehemibee is offline
post #3 of 9 Old 11-16-2010, 12:58 PM
Mik3y
Senior Member
Mik3y's Avatar
You need some di-electric grease and get to the steering column under the dash where you will find a white cup. Clean it and re-grease it with the di-electric.
DIAGNOSIS:
If the customer complains of a squeak/rubbing sound, verify that it is coming from the
lower dash seal. if so:
1. Remove the 2 push pins from the lower hush panel below the steering column
2. Remove hush panel to gain access to lower steering column seal
3. Pull the steering column seal down and inspect the white cup the seal rides on.
4. Does the white cup have black markings on white cup in the area shown in (Fig. 1)
below?
Hopefully that helps
06 Charger R/T (Silver Steel)
Mik3y is offline
post #4 of 9 Old 11-16-2010, 01:15 PM
maans88
Supporting Member (Lifetime)
maans88's Avatar
samthing is happening to me too, it almost sounds like the wiper control nob is hitting something else, correct me if im wrong
maans88 is offline
post #5 of 9 Old 11-20-2010, 10:13 PM
rodneyiii
Senior Member
rodneyiii's Avatar
Try the TSB info that Mik3y posted above first. This cures the squeak if it is coming from the cabin side of the dash seal. My noise was coming from the same seal but on the engine side of the dash seal. It's easy to see and get to. Have someone move the steering wheel back and forth while you listen for the squeak under the hood.
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
rodneyiii is offline
post #6 of 9 Old 12-13-2010, 09:54 PM
DC2010
Senior Member
DC2010's Avatar
My steering column has been making noises in the cold as well. A couple weeks ago I had it serviced at the dealership and they lubed the lower bushing on the steering column. That seemed to help for a while, but the noise has come back. Not only that, the steering column makes a "creeking" sound if I move it from side to side. The creeking sound makes me think that something is loose inside the steering column. Anyone else experienced this?
DC2010 is offline
post #7 of 9 Old 12-14-2010, 12:27 AM
USRWDV8
Senior Member
No squeak, but an occasional rubbing feel when cold. Of course, where I'm at, it's never that cold so it's no biggie. The wheel has some back and forth free play, though (just a touch).
USRWDV8 is offline
post #8 of 9 Old 12-14-2010, 08:02 AM
BOSChargerRT
Senior Member
BOSChargerRT's Avatar
Here's my right up, http://www.chargerforums.com/forums/...=134337&page=2
Jimmy - BRIGHT SILVER METALLIC SRT8 I,II,III
2toned Flat Black Vinyl,CarbonbyDesign,Billet Tech Designer,Razor Edge,SpeedLogix,KW v2,Predator 91 tune,22" 3 pc Covet Forged Wheels ,Nitto 420s,BWoody Sway ends,Hotchkis sways,Magnaflow highflow/c-back,DMH electric cutouts,22elite,BND ALL Quantum Blue/ACESIV,Killerglass,GSM intake,Danko v2 spoiler/Chin spoiler,Grip Rockers,Neffywrap
BOSChargerRT is offline
post #9 of 9 Old 12-14-2010, 10:04 PM
DC2010
Senior Member
DC2010's Avatar
Quote:
Originally Posted by BOSChargerRT View Post
That is a very thorough write up that you did on the steering column maintenance! I will have to reference your documentation if I should need to service the steering after the warranty is up. That kind of information is exactly what makes these forums so useful.
I had the dealer look at the steering column again today. This time they lubed the lower bushing with a type of grease that is supposedly meant for use in cold weather (whatever that is). Anyway, the squeak has stopped. Unfortunately, though, they didn't understand my request for the "creaking" steering wheel, so that noise was not addressed.
DC2010 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Steering Column Creek? 07_3.5_LX V6 Specific Discussion 6 12-23-2011 10:24 AM
Squeaky Steering Column Pete3500 Charger Problems/Assistance 13 12-05-2010 04:38 PM
Weird noise in steering column.. paywithdeath General Charger Discussion 10 03-03-2009 01:43 AM
Steering in the Cold metgo General Charger Discussion 26 02-13-2008 05:31 PM
steering wheel squeeking drew70 Charger Problems/Assistance 5 12-06-2007 09:04 PM
You may post new threads
You may post replies
