Belly Pan Removal (how to?) - Dodge Charger Forums
post #1 of 17 Old 11-09-2010, 01:28 PM Thread Starter
Gunder Armour
Senior Member
Gunder Armour's Avatar
(Thread Starter)
Recently (last month or so), and I don't know how, the belly pan (more to the rear) is hanging down off the ground about 5 inches. It seems the tabs came out of place and are now warped. I can see two screws on either side still holding it in place. I tried sliding it back up, but to no avail. I'll get pics later if necessary.
I want to completely remove this back section as a trip to the dealer will cost $100.
Is it as simple as unscrewing a few bolts? What size is to be used? Is this possible without a lift?
Would ramps work?
"Heroes Live Forever"
'13 Charger R/T AWD MAX
Previous '06 Charger R/T+ Owner
NOTICE: This post was just an opinion by the author. No offense should be taken. Thank you.
Gunder Armour is offline
post #2 of 17 Old 11-09-2010, 01:39 PM
Gladiator
Super Moderator
Gladiator's Avatar
Yes. You can do it without a lift. I can do it on my SRT which is lower than your car but I have long arms. (I'm 6'4".) Ramps will work. I've had my car up on those too. I want to say it's a metric size maybe 9mm. Just unscrew all the bolts you see. Can't remember how many but it's pretty self explanatory once you start.
Are you not entertained? Are you not entertained? Is this not why you are here?
Gladiator is offline
post #3 of 17 Old 11-09-2010, 02:14 PM Thread Starter
Gunder Armour
Senior Member
(Thread Starter)
Quote:
Thanks, bud! I think my arms should be long enough, lol.
post #4 of 17 Old 11-09-2010, 03:41 PM
GLHS837
Super Moderator
GLHS837's Avatar
10mm is what it is. If its hanging in the rear, I dont know how that happened, unless you back over something, or some oil change place monkey got lazy. Its not tabs that hold it back there, but bolts, two of them.
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #5 of 17 Old 11-09-2010, 03:59 PM Thread Starter
Gunder Armour
Senior Member
(Thread Starter)
Quote:
Yeah, it's strange. I've tried to make it so it doesn't rub on the ground. Maybe a pot hole?
post #6 of 17 Old 11-09-2010, 04:57 PM
GLHS837
Super Moderator
GLHS837's Avatar
Heck, theres your problem, it doesnt go like that at all. The rear bolt holes are way back on the cross member. The panel sits flat, really.
http://www.lxforums.com/board/showthread.php?t=14709
GLHS837 is offline
post #7 of 17 Old 11-11-2010, 08:45 PM
rodneyiii
Senior Member
rodneyiii's Avatar
The rear bolts are correct but the front of the panel isn't in the right place. It goes in the slots on either side of the front mounted skirt - one slot can be seen in the third photo. The belly pan has arrows molded into it showing where the 4 bolts go. You may need to remove the pan and reshape it so it will be flat. It looks like that bend has set into the plastic.
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
rodneyiii is offline
post #8 of 17 Old 11-14-2010, 12:09 PM
Scott
Senior Member
Scott's Avatar
Quote:
Originally Posted by rodneyiii View Post
the rear bolts are correct but the front of the panel isn't in the right place. It goes in the slots on either side of the front mounted skirt - one slot can be seen in the third photo. The belly pan has arrows molded into it showing where the 4 bolts go. You may need to remove the pan and reshape it so it will be flat. It looks like that bend has set into the plastic.
x 2!!!!
07 R/T, Spoiler, Daytona Insert, Glove box light, Mopar Fender CAI, Hood struts, Cabin Air Filter
Scott is offline
post #9 of 17 Old 11-14-2010, 07:21 PM
RAINMANyeh
Senior Member
RAINMANyeh's Avatar
Garage
GLHS837 is right... it's 10mm.
2017 TorRed Scat Pack - build and delivery pending - The Hive is Alive
2014 Plum Crazy R&T STP
1969 Plymouth Road Runner
- You call it "Road Rage". I call it "Aggressively maneuvering around idiots who don't know how to drive".
- You can't buy happiness, but you can buy a HEMI and that's kind of the same thing.
RAINMANyeh is offline
post #10 of 17 Old 11-14-2010, 09:40 PM
GLHS837
Super Moderator
GLHS837's Avatar
Got which end he had wrong wrong, but I got the bolt size right I replaced my anchor nuts with ones from the pick bins at Lowes
GLHS837 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Radiator belly pan neuroticdave Performance Discussion/Modifications 1 04-14-2010 08:35 AM
WTB belly pan J Blaz 15 Charger SRT-8 Discussion 3 10-19-2009 07:29 PM
WTB: Belly Pan steinism Parts For Sale/Wanted 2 01-02-2009 04:54 PM
Belly pan off - what negatives are there? Sublimeon22s Performance Discussion/Modifications 5 07-24-2008 06:50 PM
Belly pan flew off??? Kenny Pollock Charger Problems/Assistance 26 07-10-2008 02:42 PM
You may post new threads
You may post replies
