Dash lights flashing after oil change..?? - Dodge Charger Forums
post #1 of 4 Old 10-18-2010, 05:59 PM Thread Starter
Haf-A-Mil
Junior Member
Send a message via AIM to Haf-A-Mil
(Thread Starter)
Hello all,
First off I'd like to say thanks for all the help thats available on this forum. It's helped me out a whole lot. Well I have a 2006 Dodge Charger SE, I'm at about 58k miles. So wanting to be more handy with my car I did my first oil change about 2 weeks ago. Prior to me doing this oil change, I've been letting my local shop do them. They use the Mobil1 synthetic oil (5w-20) with a mobil1 filter (M1-204). So this was the same stuff I bought at my local auto parts store to do my oil change. Real easy job didn't have any issues. So about 2 days later after I did the oil change my dash lights start flashing (like how when you turn on your car). They stay on for a brief moment and then go off. And then maybe a little while later it will happen again. Then there are some days it doesn't happen at all. Was there something else I was supposed to do during the oil change that would cause the lights to flash? Or maybe just a coincidence it started happening around the same time? I read somewhere that maybe some wiring could be loose or some condensation build up somewhere could be the cause. Maybe this has happend to someone else and someone knows the answer. Thanks in advance for any help.
Haf-A-Mil is offline
post #2 of 4 Old 10-19-2010, 12:33 AM
AKCallahan
Senior Member
AKCallahan's Avatar
Quote:
Originally Posted by Haf-A-Mil View Post
Hello all,
What all cluster lights come on?
Tank: 2006 Dodge Charger V8 Hemi 5.7L R/T R&T
Twitch: 2006 Dodge Ram 1500 Laramie Edition 4x4 5.7L HEMI
AKCallahan is offline
post #3 of 4 Old 10-19-2010, 09:13 AM Thread Starter
Haf-A-Mil
Junior Member
(Thread Starter)
The lights that come on are the same ones when starting the car. So, its the battery light, seatbelt light, washer fluid, oil light, the red dot to the far left, etc. All of the needles got the far left like when the car is shut off. Then they reregister (so the mph's go back to where they were, the thermostart goes back to the middle, and the gas needle goes back to the correct reading as well). One other thing, it did it alot this morning on the way into work. I did the key trick ACC, ON..blah blah and got the code 110A. Happen to know what that code refers to? I googled it and couldn't find a thing about 110A. Hope this helps, any ideas?
post #4 of 4 Old 10-19-2010, 02:13 PM
AKCallahan
Senior Member
AKCallahan's Avatar
Only thing I could come up with is Lost communication with SCCM. Sometimes if the battery is disconnected, you need to recalibrate the steering angle sensor. Just start the car and turn the steering wheel lock to lock.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Passenger Airbag Light Flashing On Dash? BlackChargerRT Charger Problems/Assistance 8 04-11-2014 08:40 PM
Flashing Reverse Lights captthomason Exterior Discussion/Modifications 5 08-31-2009 10:11 PM
how can i change the dash,switch,and steering wheel lights? imekgyalcum Interior Discussion/Modifications 5 06-02-2008 12:12 AM
Flashing dash lights in rain sirwoj Charger Problems/Assistance 6 11-09-2007 09:58 PM
Fog lights flashing. goval General Charger Discussion 2 02-23-2007 10:21 AM
You may post new threads
You may post replies
