horn fuse - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 4 Old 10-03-2010, 05:47 AM Thread Starter
charger7658
Junior Member
(Thread Starter)
horn fuse
I have 2009 dodge charger, my problem is simple .... the horn is not working
But I couldn't find the fuse number in the owner's manual.. Any help
Thanks
charger7658 is offline
post #2 of 4 Old 10-03-2010, 07:51 AM
RAINMANyeh
Senior Member
RAINMANyeh's Avatar
Garage
I loctaed this fuse cross reference for a 5.7
Front Power Distribution Center Fuses
# Amp
1 20 Yellow Left High Beam Headlight
2 20 Yellow Right High Beam Headlight
3 15 Dk. Blue Adjustable Pedal
4 20 Yellow Horn
5 25 Clear Headlamp Washer If Equipped
6 15 Dk. Blue Front Control Module (FCM)
7 20 Yellow Fog Lamp
8 15 Dk. Blue Park Lamp
9 15 Dk. Blue Non ABS Brakes
10 5 Orange Starter
11 20 Yellow Auto Shutdown/Powertrain Control Module (PCM)
12
13
14 25 Clear Powertrain Control Module
15 20 Yellow Injectors, Ignition Coils
16 15 Dk. Blue Powertrain Control Module
17 30 Pink Antilock Brake System (ABS) Valves
18 30 Pink Windshield Wiper/Washer
19 50 Red Radiator Fan
20 20 Lt. Blue Starter
21 50 Red ABS Pump Motor
22 40 Green Radiator Fan High/Low
23 50 Red High Intensity Lighting
24
25 30 Pink Lighting Left High Beam/Right Low Beam
26 20 Lt. BlueTransmission
27 30 Pink Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
# Amp
1 60 Clear Ignition Off Draw
2 40 Green Battery
3
4 40 Green Battery
5 30 Pink Heated Seat/Steering Column
6 20 Yellow Fuel Pump
7
8 15 Dk. Blue Ignition Start/Run - Start
9 20 Yellow Console Power Outlet
10 10 Red Rear Fog Lamp If Equipped
11 25 C/BRKR Memory Module/Door Locks
12 25 C/BRKR Passenger Power Seat
13 30 C/BRKR Door Module Run/Acc/Delay
14 10 Red Sentry Key/Remote Keyless Entry/Cluster
15 20 Yellow Brake Light (5.7L)
16 20 Yellow Power Outlet Trunk - if equipped
17
18 20 Yellow Selectable Power Outlet
19 10 Red Stop Lamp
20 20 Yellow Rear Wiper If Equipped
21
22
23
24
25
26
27 10 Red Airbag/Occupant Classification Module
28 10 Red Curtain Airbag - if equipped
29 5 Orange Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30 10 Red Steering Column Module/Power Mirrors - if equipped
31
32
33
34
35 5 Orange Power Antenna/Garage Door Opener/Ignition Delay
36 20 Yellow Radio/Navigation
37 15 Dk. Blue Transmission
38 5 Orange Analog Clock/Garage Door Opener
39 10 Red Heated Mirror
40 5 Orange Power Mirror
41 10 Red Climate Control Module/Headlamp Leveling if equipped/Rear Park Assist if equipped/Tire Pressure Monitoring if equipped
42 30 Pink Automatic Temperature Control (ATC) Blower Motor
43 30 Pink Rear Defroster
44 20 Lt. Blue Audio Amplifier
2017 TorRed Scat Pack - The Hive is Alive
1969 Plymouth Road Runner
- You call it "Road Rage". I call it "Aggressively maneuvering around idiots who don't know how to drive".
- You can't buy happiness, but you can buy a HEMI and that's kind of the same thing.
RAINMANyeh is offline
post #3 of 4 Old 10-03-2010, 07:52 AM
RAINMANyeh
Senior Member
RAINMANyeh's Avatar
Garage
The horn itself could have gone bad or the contact points in the steering wheel.
post #4 of 4 Old 10-03-2010, 09:40 PM
mnunes
Supporting Member (Lifetime)
mnunes's Avatar
Power for the horn comes from the TIPM (totally integrated power module) under the hood; there's no separate fuse for the horn itself. You may want to check fuse #30 under the hood but if that's out I'd expect a lot more than the horn to not be working.
The circuit for the horn switches goes through the steering column control module. It's possible you have bad switches like Rainman said or the connector to/from the SCCM could be loose.
If you haven't been doing any work with the steering wheel, I'd let the warranty cover this one.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Horn doesn't work, but the fuse is OK 3APA3HO Charger Problems/Assistance 11 02-12-2011 08:32 PM
New Horn Sublime333 Interior Discussion/Modifications 22 11-23-2008 05:50 PM
New Horn Sublime333 Interior Discussion/Modifications 0 11-05-2008 08:59 PM
How to set up an empty fuse in the factory fuse box? NummThumz Audio - Alarms - Navigation - Electronics 7 09-26-2008 07:02 PM
Fuse 11 fuse pull question tank8289 Performance Discussion/Modifications 2 10-02-2007 12:08 PM
You may post new threads
You may post replies
