Remote Start shuts off after 10 seconds - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 10-02-2010, 09:02 PM
Daytona606's Avatar
Daytona606 Daytona606 is offline
Senior Member
Lifetime Supporting Member
Hey guys - out of the blue i have an issue with the remote start. i will start it and after about 10 seconds the car will shut off. the problem started out of nowhere and happens everytime. any thoughts? It is a stock remote start.
__________________
2009 HO Superbee 412
2013 SRT8 Jeep Grand Cherokee
  #2
Old 10-03-2010, 08:39 AM
CTown R/T R&T's Avatar
CTown R/T R&T CTown R/T R&T is offline
Senior Member
I had the same issue on my van this summer. Would start, run for ten seconds and as soon as the lights came on to signify its running. It would shut off. Took it to the shop, they said it runs through a checklist and shuts the car if off to protect it if theirs a problem. I didn't have time to leave it, so I disconnected it. Later this summer, my battery died because my alternator failed. After replacing the alternator and battery, I reconnected the remote start and its worked fine ever since.
  #3
Old 10-03-2010, 01:37 PM
ChicagoSRT8 ChicagoSRT8 is offline
Senior Member
any check engine lights? mine does the same n then it shuts off due to a cel due to my jba exhaust. Havent gotten around to fixing it.
__________________
2008 Charger SRT8
13.5@103MPH JBA exhaust/ Green Filter drop in
  #4
Old 10-04-2010, 07:42 PM
chargersxt06 chargersxt06 is offline
Member
what alarm system do u have and how long have you had it?
  #5
Old 10-04-2010, 08:05 PM
Daytona606's Avatar
Senior Member
Quote:
you da man! yes now that you mention it i have a cat code. i have had jba shorties for almost 2 years never had a code, then i blew the gasket and had it replaced, a week later i got the code. they have to be related. thanks for your input. any clue as to the cat code, or a fix?
__________________
  #6
Old 10-04-2010, 08:06 PM
Daytona606's Avatar
Senior Member
Quote:
no alarm - stock oem remote start. never had a problem in 2.5 years.
__________________
  #7
Old 10-04-2010, 08:39 PM
Member
o ok i was asking because i have had 2 different remotes starters in 2 diff cars after a year or 2 i started gettin problems like car shutting off for no reason after running for a few mins and not starting also it killed my battery a few times i found that the connections to the remote starter would get loose and intermittently work so i used zip ties to hold the plugs in tight and havnt had problems since just my personal experience...
  #8
Old 10-07-2010, 12:48 AM
Senior Member
Quote:
The CEL has to be reset after you take care of the problem.
I read on here about using 02 sensor foulers. Let me see if I can find it.
Now that it's getting cold I must get this fixed!
__________________
2008 Charger SRT8
  #9
Old 11-14-2010, 07:55 PM
Daytona606's Avatar
Senior Member
Awesome - i appreciate it. sorry for the delay in response, been pretty busy and havent logged in in a while.
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
My car will remote start and I do not have remote start on my fob. cue2671 General Charger Discussion 5 03-10-2010 05:08 PM
Trouble at the pump. It always shuts off after a few seconds. Devilgear Charger Problems/Assistance 10 08-28-2009 09:15 AM
3.5L Stalls seconds after engine start VaSEPlus Charger Problems/Assistance 3 05-30-2008 08:38 PM
Passenger Seat Heater - on for 2 seconds and shuts off PUREVIL Charger Problems/Assistance 4 03-18-2008 06:02 PM
Remote starter delay - shuts off then back on relltherell Audio - Alarms - Navigation - Electronics 6 08-26-2007 11:15 PM
© AutoGuide
