Engine code p0520 - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 08-27-2010, 11:55 AM
06Whistlin'DixieR/T's Avatar
06Whistlin'DixieR/T 06Whistlin'DixieR/T is offline
Member
Engine code p0520
Key dance shows p0520 engine oil pressure sensor. Light came on while driving today. Does this just mean I need a new sensor or something else? And if so does anyone know the part number or where I can get one?
__________________
'06 R/T, SLP Loudmouth I, K&N FIPK cold air, Royal Purple
1967 Firebird 400... in restoration mode!
  #2
Old 08-27-2010, 05:30 PM
richd richd is offline
Senior Member
Quote:
From what I see what the code says,I would check your wiring for a short or bad wire,here is what code PO520 says:
Oil pressure Sensor signal circuit is open or shorted to ground
Oil pressure Sensor signal circuit has high resistance
5v supply circuit has high resistance
5v supply circuit is shorted to ground
Oil pressure Sensor ground circuit has high resistance
  #3
Old 08-28-2010, 07:50 PM
Member
After I filled up with gas today the light went off. but now its back on. too bad i know absolutely nothing about wiring!
__________________
  #4
Old 02-15-2011, 07:54 PM
eggsandbacon eggsandbacon is offline
Member
i got this code too...
  #5
Old 02-15-2011, 10:11 PM
nealuss nealuss is offline
Senior Member
Send a message via Yahoo to nealuss
Looks like you need an oil pressure switch. Here's a thread from 300Cforums
http://www.300cforums.com/forums/pro...lfunction.html
__________________
2011 Laser Blue Mini Cooper S Turbo 6-speed manual
2007 Stone White Charger R/T: Traded 09/27/11 Gone But Never Forgotten
  #6
Old 04-28-2012, 02:44 PM
NBx33's Avatar
NBx33 NBx33 is offline
Senior Member
So to revive an old thread.
Was the oil pressure sensor the fix to the code?
__________________
U R NOT E #608 Top Banana R/T Team SkidkidS-Founder - My Cardomain !! View, Vote, Nominate Please!!
LX & BEYOND Best of Show Daily Driver 2 years running. Thanks.
Its best to fail in an attempt to be original then succeed in following somone's footsteps.
-Herman Moore
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Engine Code KSMIKE Charger Problems/Assistance 2 08-15-2009 07:35 PM
Engine Code Bootstrap Charger Problems/Assistance 3 06-03-2009 09:58 AM
Help engine code 0645 msierra519 Charger Problems/Assistance 5 01-28-2009 11:13 AM
Engine Identification code Charger R/T Performance Discussion/Modifications 3 04-05-2007 04:23 PM
0300 Engine Code Again!?!?!?!?!?! marlman V6 Specific Discussion 2 10-26-2006 04:15 AM
© AutoGuide
