I have a DTC P0481 - Dodge Charger Forums
post #1 of 11 Old 07-19-2010, 07:15 PM Thread Starter
Lady6605
Junior Member
(Thread Starter)
I have a DTC P0481
I have a 2006 Dodge Charger R/T my car overheated the coolant was boiling only a small amount of steam coming from the left front, let the car cool down and was able to get it home. We replaced the coolant temperature sensor and both radiator fans were cracked. We replaced the fans with Derale racing fans and they are pulling 1740 CFMS. I now have a DTC P0481 for fan 2 relay open circuit what should my next step be should we replace the fan relay? If so where are they located?
Lady6605 is offline
post #2 of 11 Old 07-19-2010, 07:38 PM
InvictuSRT8
Supporting Member (Lifetime)
InvictuSRT8's Avatar
Garage
Send a message via AIM to InvictuSRT8
Welcome to the forums!
Where/how much were the new fans if you don't mind me asking? I had radiator issues a while back as well and long story short there was some fishy business about them having to replace my fans because of an apparent TSB.
Sorry I can't help you, however I'm sure someone can provide detailed info on your question
A modded 06' 370 & an 07' 426
InvictuSRT8 is offline
post #3 of 11 Old 07-19-2010, 08:02 PM Thread Starter
Lady6605
Junior Member
(Thread Starter)
I bought 2 Derale fans from Summit Racing and both cost 171.00 no shipping. The delivery was quick I had the fans within 2 days of order when I couldn't get any fans locally they are all on backorder. According to what I am researching online dodge seems to have a problem with radiator fans I was fortunate in that it took 107,000 miles for it to happen.
Lady6605 is offline
post #4 of 11 Old 07-19-2010, 09:20 PM
InvictuSRT8
Garage
Quote:
yeah my issue was at 30k so I luckily was under warranty (dealership only told me it was a split radiator). What was fishy was one rep leaving a message about him ordering me new fans and to make another appointment to get them installed, but when I called back that guy had been "let go" and they "saw no TSB or orders for new fans"
post #5 of 11 Old 07-20-2010, 05:26 AM Thread Starter
Lady6605
Junior Member
(Thread Starter)
While that sounds fishy I have worked in a dealership as a service writer for the past 20 years and I know that there are some dishonest people out there. It does happen. I know for a fact that there are no TSB's on the charger for the fan. I have been out of work for a little while but up to that point there were not any as well when I contacted a dealer they told me that there was no known problems with the fans and everywhere you look on the forum people have had cracked fans so I guess it is a problem.
Lady6605 is offline
post #6 of 11 Old 07-20-2010, 12:57 PM
richd
Senior Member
Your Fan relay should be in the front power distribution center under the hood,cavity 22.On your code,i would double check the wiring,here is more on your code:PO481
Possible Causes:
HFAN relay power circuit is open from the relay to fused power
HFAN relay control circuit is open or shorted to chassis ground
Fan relay(s) failed
PCM has failed.
richd is offline
post #7 of 11 Old 07-20-2010, 04:08 PM Thread Starter
Lady6605
Junior Member
(Thread Starter)
Thank you for the info Rich. It wouldn't be the first time I had a problem with the wiring. That was the area I thought the relay was in. Thank you again. I will post again when my vehicle is finally fixed and not overheating anymore.
Lady6605 is offline
post #8 of 11 Old 07-20-2010, 05:28 PM
CentralNJRT
Senior Member
CentralNJRT's Avatar
Keep an eye on your engine, did it overheat to the point that you saw your temp gauge shot all the way up and stayed there for a while? Not to scare you, but at least a handful of R/T's that have over heated have dropped a valve and lost at least one piston. Some guys just get it fixed for a few thousand, others get the engine replaced.
Not saying its gonna happen, just letting you know it has happened and from what I've seen the general consensus is that the engines over heating was directly related to the valve failing. So keep an eye on that.
Magnesium Pearl '06 R/T
AFE Stage II---JBA Shorites---High Flow Cats---180 Jet Thermo---Diablo---Blacked out emblems---Black honey comb grille---Black LED tails
Full BND Fluids, Quantum Blue Oil, Gear Lube, Trans Fluid, ACES IV, Power Steering, Coolant.
CentralNJRT is offline
post #9 of 11 Old 07-20-2010, 07:07 PM
vbouncer
Member
I had my engine overheat due to a faulty hose (it came off of the upper radiator) and this caused my engine temp to soar and the needle pegged this all took about 2 minutes, I limped to a gas station shut it down, but it was too late the damage was already done, the valve were shot the piston shot up and slammed into the spark plug. It was new engine time, I had 114K on it when this happened. I got lucky and found an engine from a forum member over at the lx place.
GL with yours.
vbouncer is offline
post #10 of 11 Old 06-09-2015, 11:05 AM
trsctt
Junior Member
Hey i have the same code show up when my service engine light came on but my car has not yet overheated what should be my next step how do i test the fans to see if they come on when needed
trsctt is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Dtc P0430 karace1 Charger Problems/Assistance 24 07-22-2011 01:57 PM
DTC P0700 and C2114 Kaikou Charger Problems/Assistance 5 07-02-2007 04:01 AM
DTC help from anyone SRT8TT General Charger Discussion 1 01-17-2007 09:32 PM
DTC help from anyone SRT8TT Charger SRT-8 Discussion 0 01-17-2007 08:52 PM
DTC Code P1521 coliseum General Charger Discussion 3 12-25-2006 11:58 PM
You may post new threads
You may post replies
