Steering angle sensor internal C2205 & C121A - Dodge Charger Forums
post #1 of 18 Old 07-12-2010, 03:46 PM Thread Starter
Draupner
Member
(Thread Starter)
Hi,
My ESP/BAS light is always lit since a few weeks. The dealer found trouble code C2205 and C121A, indicating an error with the steering angle sensor. Reset procedure does nothing and the code comes back after clearing it. They want to replace the sensor. My question is; can I check anything else that might cause this trouble code rather than the actual sensor, like a fuse or something? Any ideas? Just to rule out things before ordering parts etc.
Draupner is offline
post #2 of 18 Old 07-12-2010, 10:04 PM
mnunes
Supporting Member (Lifetime)
mnunes's Avatar
Checking both of those codes in the service manual it sure sounds like the sensor is bad, especially if performing the reset procedure doesn't work.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #3 of 18 Old 07-16-2010, 06:13 AM Thread Starter
Draupner
Member
(Thread Starter)
Sensor is now replaced and problem gone.
Draupner is offline
post #4 of 18 Old 10-29-2013, 12:23 PM
300x300
Junior Member
I have a 2008 Chrysler 300 and the scanner shows Code " C121A Steering wheel sensor is not initializing" So I went and bought one (Part # 5135969AA) and replaced it , the light turned off , I was happy for 5-10 min, then it came back on again ,,, Hate it.
300x300 is offline
post #5 of 18 Old 11-03-2013, 07:58 PM
TBird100636
Senior Member
TBird100636's Avatar
Question
Quote:
Light comes back on when making moderate left turn? If so read this:
There is a STAR case relating to steering shaft protrusion in relation to the ESP light coming on from SAS calibration. It involves removing the steering wheel & SCM (plastic collar containing clockspring, cruise switch, SCCM, Multifunction Switch and SAS)and measuring the shaft protrusion. But... you say it comes on when making left turns. I had an 08 with this exact same problem. Found the STAR case and saved some time. I didn't measure the column, but skipped ahead and just tried the repair procedure for if the column was ok. It worked. The procedure mistakenly instructs to use a T25 Torx screwdriver. You have to use a T30 Torx screwdriver, not a replaceable bit type. Here's the procedure:
Repair Procedure:
1. Through the hole in the bottom of the SCCM (refer to illustration) insert a T30 Torx driver and loosen the clamp screw approximately 4 turns. Do not remove the screw.
2. Pull the SCCM upward on the column tube toward the steering wheel as far as possible. The amount of movement is limited because the clamp screw is captured within an oval shaped hole in the tab on the casting of the column tube.
3. Re-tighten the screw.
4. Test drive the vehicle.
On the car I fixed pulling the SCM towards the steering wheel evenly it did not move at all. I believe I pulled only on the left side and it moved. I then held it pulled out and tightened the screw. Give it a shot. If you want the full procedure PM me your eMail.
2011 Dodge Charger R/T Plus AWD- Redline-
2006 Dodge Charger R/T- Inferno Red- Gone-
TBird100636 is offline
post #6 of 18 Old 11-05-2013, 05:25 PM
chargerfreak08
Senior Member
chargerfreak08's Avatar
my car was doing the same thing (08 rt), i followed the STAR case and now it works perfectly. and it was only with left turns, got a bit nasty in wet weather, cause my trac control would come off in the middle of a corner and I would get tire spin
'08 Dodge Charger R/T 5.7L
Thrush "Welded" Two-Chamber Mufflers w/axle dump
K&N Box Filter
255/55R18 Firestone Destination ST 100W x4
20% Window Tint & Eyebrow Tint
'Dipped Wheels, Emblems, Corner Lights, Spoiler, & Taillights
Painted Brake Calipers
chargerfreak08 is offline
post #7 of 18 Old 11-06-2013, 04:41 PM
300x300
Junior Member
TBird100636,
First , thanks a lot for replying,
So If I'm not mistaken , I would say yes most probably it happens when I turn left. (Almost 90% sure).
And to fully understand that Fix you suggesting , I DO NOT need to take out or dissemble any parts ? I don't need take the AirBag or the ESP or any of that jazz out ?
I peaked last night on that Hole and I think I found it , Well its the only hole at the bottom of the SCCM. So just to get that Clear I just need to lose the screw inside that hole and pull the SCCM towards me (To the outside so its fully Extended ) then re-tight that screw ? That's it ?
300x300 is offline
post #8 of 18 Old 11-06-2013, 04:46 PM
300x300
Junior Member
chargerfreak08,
Can you please provide more details on the fix steps ?
PLEASE and thank you
300x300 is offline
post #9 of 18 Old 11-06-2013, 04:47 PM
300x300
Junior Member
More Info please ?
chargerfreak08,
Quote:
300x300 is offline
post #10 of 18 Old 11-06-2013, 04:48 PM
300x300
Junior Member
Couple of questions ?
TBird100636,
Repair Procedure:
300x300 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
SRT power steering cooler and outer air temp sensor and horns exposed GLHS837 General Charger Discussion 1 01-08-2009 01:20 PM
Camber angle? richrotors Wheels/Tires/Brakes/Suspension 2 06-15-2008 08:02 AM
iphone has bigger internal amp than ipod? white06r/t Audio - Alarms - Navigation - Electronics 2 10-09-2007 02:58 PM
What is the IAT sensor & what does it do? ssballow V6 Specific Discussion 12 07-08-2007 09:29 PM
Internal temperature not accurate. gweempose General Charger Discussion 8 12-12-2005 12:22 PM
You may post new threads
You may post replies
