P0325-knock Sensor 1 Circuit - Dodge Charger Forums
post #1 of 11 Old 06-21-2010, 10:50 PM Thread Starter
Bad Mojo
Junior Member
(Thread Starter)
I just bought an 08 Charger and have an extended warranty. It runs like a champ. This code will throw and I notice no difference in performance. After three drive cycles the code clears itself and the MIL goes off. Took it to dealer twice, first time code was just reset. Second time light had come on and cleared itself but I took it back anyways. Mechanics took it for a few days, drove it and could not get the code to throw. Discovered the AC clutch was cycling and was low on freon, so added freon and said let them know if it comes on. 30 mins after leaving dealer it came on again, same code. drove all weekend and code cleared itself. Code came on again this afternoon, I did three more drive cycles and the code is cleared again. This is after finding out I wasn't able to drop the car off tonight. So I am at a loss. I'm thinking faulty sensor or maybe adjustment due to altitude, possibly. I bought in Colorado Springs, carfax says its a Florida car. Mechanic is reluctant to dig unless the light is on, but it clears before I can get it to them. Any thoughts? Thanks
08 Charger, 2.7L, 44k. No mods.
Bad Mojo is offline
post #2 of 11 Old 06-21-2010, 11:32 PM
richd
Senior Member
Do you hear any pinging when your driving or accelerate?I would check and make sure you have a good connection with the wiring,Here are causes of you code:
Possible Causes:
Knock Sensor connector is damaged or shorted
Knock Sensor signal circuit open or grounded
Knock Sensor signal circuit shorted to return circuit
Knock Sensor return circuit is open
Knock Sensor not tightened properly
Knock Sensor damaged or has failed
richd is offline
post #3 of 11 Old 06-21-2010, 11:35 PM Thread Starter
Bad Mojo
Junior Member
(Thread Starter)
I don't think so, I have listened, my dad has, and the mechanic even used a stethoscope and said there wasn't anything. Everything I have read points me to the sensor.
Bad Mojo is offline
post #4 of 11 Old 06-22-2010, 05:51 PM Thread Starter
Bad Mojo
Junior Member
(Thread Starter)
Update
Will be taking to Dodge on Thursday night, they say it sounds like sensor also. Will post results. Thanks for the help.
Bad Mojo is offline
post #5 of 11 Old 06-25-2010, 04:48 PM Thread Starter
Bad Mojo
Junior Member
(Thread Starter)
Update 2
mechanic has right valve cover and timing cover off.....not to sure I am liking this. However, may be common for this issue. Will update when I know more.
Bad Mojo is offline
post #6 of 11 Old 06-25-2010, 06:25 PM
richd
Senior Member
The knock sensor on the 2.7 is under the throttle body,and intake and fuel inj. plate has to be removed,so it sounds like its not easy job,let us know what happens and thanks for update,Good Luck.
richd is offline
post #7 of 11 Old 06-28-2010, 06:37 PM Thread Starter
Bad Mojo
Junior Member
(Thread Starter)
ready for this...
so....the top end is shot and the mechanic is awaiting authorization to pull the oil pan to see if the whole engine needs to be replaced. Said it has been oil starved and there are holes in the heads. I have put 400 miles on this car. I did buy an extended warranty/service contract that "covers" everything. My only concern is the warranty saying they won't cover it! They have an inspector on the way and I am awaiting their take on it until I authorize anymore work. very stressed and very concerned.
Bad Mojo is offline
post #8 of 11 Old 06-28-2010, 06:58 PM
richd
Senior Member
If you have a extended warranty,then there may be a deductible you pay.If you just bought this not long ago,then the dealer you bought it from should have given you some kind of a warranty.They have had some problems with the 2.7,and I think they should honor the warranty.Sorry your having this problem,but I think it will be covered,let us know and Good Luck.
richd is offline
post #9 of 11 Old 06-28-2010, 07:07 PM Thread Starter
Bad Mojo
Junior Member
(Thread Starter)
thanks for the support, yes I have a $100 deductible, but that's nothing compared to an engine overhaul/replacement. That's why you buy a service plan right? I have also spoken to the dealer and they are more than willing to help and assured that they would be very suprised if it was not covered and they would weigh in if it came to that. Will update as I know more.
Bad Mojo is offline
post #10 of 11 Old 06-29-2010, 04:58 PM Thread Starter
Bad Mojo
Junior Member
(Thread Starter)
Another update
Ok, the top end is definitely shot, the oil pan is being dropped to determine if a whole engine is required. Claims adjuster has looked at it and "there are no foreseen problems with the warranty honoring the claim at this time". That is what the warranty company told me. So good news, I think. Will know more tomorrow.
Bad Mojo is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
P2078-intake Manifold Tuning Valve Position Sensor Circuit High reddcode Charger Problems/Assistance 0 06-22-2009 08:53 AM
Knock Sensor Location? Ronaldo Charger Problems/Assistance 3 08-05-2008 01:09 PM
Knock Sensor repaired...Power returned FLUBYU Charger SRT-8 Discussion 1 06-02-2007 09:06 PM
Knock, Knock whos there or ........ Ruff n Tuff RT Charger Problems/Assistance 16 04-17-2007 11:32 PM
Does the 6.1L have a knock sensor? high888 Charger SRT-8 Discussion 15 01-11-2007 02:07 PM
You may post new threads
You may post replies
