suspension diagram??????? - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 19 Old 06-03-2010, 01:09 AM Thread Starter
dannyh86
Senior Member
dannyh86's Avatar
(Thread Starter)
anyone know where i can see a suspension diagram or pictures with the name of the parts? i need to know how these parts look and where the are exactly; rear, knuckle, lower control arm, tie rod w/ toe bolt, and bearings/hubs. front; inner/outter tie rod ends. thanks in advance
2007 DODGE CHARGER
dannyh86 is offline
post #2 of 19 Old 06-03-2010, 05:58 AM
navy48
Senior Member
navy48's Avatar
Quote:
if you PM me with a fax number, I can fax pics out of our EPC.
navy48 is offline
post #3 of 19 Old 06-05-2010, 08:14 AM
slip
Senior Member
Here are some pics.
Name:	Ball joint.JPG
ID:	53685   Click image for larger version
ID:	53686   Click image for larger version
Name:	Upper control Arm.JPG
ID:	53687   Click image for larger version
Name:	Tension Strut3.JPG
ID:	53688   Click image for larger version
slip is offline
post #4 of 19 Old 06-05-2010, 08:18 AM
slip
Senior Member
More pics....
Name:	Tension Strut, ball joint.JPG
ID:	53690   Click image for larger version
Name:	Lower Control Arm, Sway Bar.JPG
ID:	53691   Click image for larger version
Name:	Front supsension.jpg
ID:	53692   Click image for larger version
Name:	Rear Suspension 1.jpg
ID:	53693   Click image for larger version
Name:	Rear suspension 2.jpg
slip is offline
post #5 of 19 Old 06-05-2010, 08:22 AM
slip
Senior Member
Name:	Rear Suspension Diagram.JPG
ID:	53695   Click image for larger version
Name:	front suspension.JPG
slip is offline
post #6 of 19 Old 06-05-2010, 09:21 AM
Brad SXT
Senior Member
Wow excellent information!
08 SXT
Predator. Big Bully. Quantum Blue.
15.477 @ 89.73 mph
Brad SXT is offline
post #7 of 19 Old 06-05-2010, 11:47 AM Thread Starter
dannyh86
Senior Member
dannyh86's Avatar
(Thread Starter)
slip thanks for the info, really great info. really appreciate it
dannyh86 is offline
post #8 of 19 Old 05-12-2014, 11:35 AM
Treehop
Senior Member
I've been trying to find a solution to my suspension/steering problem and came upon this old thread, because I am no mechanic and don't know which parts are what. I've recently had coilovers installed, and an issue that's been bugging me prior to the swap are still there, which leads me to believe that whatever parts the coilovers replaced wasn't the source.
1) When I turn my streering wheel, I hear this groaning noise from the outside of the car. I don't think this is normal as it didn't do this when my car was new. What's the cause?
2) When I go over bumps, I hear an old rusted spring bed creeking sound. What's causing this? I've read that there's some parts on the front suspension that are prone to failure in these cars. What are they, and are there any aftermarket solutions? Or did they fix the issue at a certain year? Are any mopar parts like from the SRT interchangeable with the RT?
3) I am getting a harsh steering wheel shake/shudder when braking from high speeds. I don't think it could be my rotors/pads as they are new and I have bedded them in properly and have retorqued the nuts as per recommendations. I've noticed that on one of my wheels, there's an empty spot where a balancing weight may have been on before, but it could have been there from when I first got the wheels and had them balanced. What do you think?
Any help would be appreciated.
My specs: 2010 Charger R/T AWD
Treehop is offline
post #9 of 19 Old 07-18-2014, 03:10 PM
moxieboy
Senior Member
moxieboy's Avatar
Smile
how cool would it be to have arrows to the bolts with torque specs .......... hint hint
moxieboy is offline
post #10 of 19 Old 07-20-2014, 11:38 PM
Razorx
Senior Member
Razorx's Avatar
Subscribed
2006 Dodge Charger Daytona #1964
Razorx is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
does anyone have wiring diagram of homelink QuickD Audio - Alarms - Navigation - Electronics 20 09-22-2009 02:16 PM
Fuse box diagram? wat u gon do? Charger Problems/Assistance 2 06-01-2009 07:21 PM
stereo wiring diagram rollin22s Audio - Alarms - Navigation - Electronics 0 03-28-2008 03:47 PM
audio wiring diagram ekaz Audio - Alarms - Navigation - Electronics 0 04-04-2007 12:19 AM
I need help with wiring diagram goval General Charger Discussion 2 03-13-2007 04:35 PM
You may post new threads
You may post replies
