Brake light/Rear turn signal failure - Dodge Charger Forums
post #1 of 8 Old 05-06-2010, 09:46 PM Thread Starter
walken
Senior Member
walken's Avatar
(Thread Starter)
My rear right turn signal/brake light isn't working. The front right signal was flashing rapidly so I changed the rear bulb, the filaments are not burnt out on the old bulb (I know there are two filaments, one for brake/signal and one for running lights) I checked the wires by eye and nothing looks frayed or loose.
Now i'm a little bit worried, as I don't want to take it to a mechanic and have to pay an arm and a leg and can't really afford it at the moment anyway...
Any suggestions given that it's not the bulb?
Thanks.
walken is offline
post #2 of 8 Old 05-06-2010, 10:00 PM
Gladiator
Super Moderator
Gladiator's Avatar
Does the harness look damaged at all?
Are you not entertained? Are you not entertained? Is this not why you are here?
Gladiator is offline
post #3 of 8 Old 05-06-2010, 10:05 PM Thread Starter
walken
Senior Member
walken's Avatar
(Thread Starter)
No, nothing is loose, everything appears to be connected as it should be.
walken is offline
post #4 of 8 Old 05-06-2010, 10:11 PM
Gladiator
Super Moderator
Gladiator's Avatar
I only ask that because getting the bulbs out of the lights can be hard sometimes. They stick and you pull you know? Have you checked fuses?
post #5 of 8 Old 05-07-2010, 07:16 AM Thread Starter
walken
Senior Member
walken's Avatar
(Thread Starter)
After checking in the manual and the haynes manual I couldn't really ascertain which fuses related to the brake/signal lights. Neither manual specifies a fuse for those lights. If the fuse had gone, why would it only affect one side, my past experience with blown fuses on cars always left both sets of lights not working.
There must be an electrical problem somewhere, my worry is that it's going to be expensive to get to the root of the problem.
walken is offline
post #6 of 8 Old 05-10-2010, 01:04 PM
Lugnut
Member
Normally single lights that do not work (after bulb replacement) on a circuit with multiple lights (like your case) mean that the socket itself has a problem of some kind.
This is usually corrosion but could also be physical damage. Ensure that no corrosion or physical damage is present.
If the socket is OK try this to narrow it down:
1. Remove the inoperative taillight bulb from the socket.
2. Activate the right turn signal
3. Using a voltmeter (can be a cheapie from Radio Shack, etc) probe for voltage at the bulb contacts in the socket.
Note: The black wire (with or without a stripe) is ground. The non-black wire (with or without a stripe) is power to the bulb.
4. If you do get voltage then test the other bulb connection for a proper ground.
Let us know what you find.
Lugnut
Lugnut is offline
post #7 of 8 Old 05-11-2010, 07:25 AM Thread Starter
walken
Senior Member
walken's Avatar
(Thread Starter)
Man... my mechanic took a look at it, changed the bulb and it works fine now. So it looks like I bought a bad bulb, the filaments looked fine on both the old bulb and the new one I got. Lucky for me it cost me nothing for the mechanic to fix it. Always check your bulbs.... I should have checked it with the left hand signal.
Thanks for all your suggestions.
walken is offline
post #8 of 8 Old 05-14-2010, 07:51 AM
bostonchrgr
Member
bostonchrgr's Avatar
Be prepared for it to happen again. That happened to me as well and with every closure of the trunk the light may tend to work or not. I finally had to go to the dealer and they charged me to replace the wiring in the back of the car. I think the whole bill came to $350 but that included a replacement of the third brake light so I am not sure what it cost to fix alone. Good luck...
bostonchrgr is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Right rear turn signal not working!!! SD_SRT6 2.7 Hemi Charger Problems/Assistance 2 03-09-2010 04:44 PM
2 Questions: Head- and Taillight (disable DRL) (separate turn signal and brake light) Player87 Audio - Alarms - Navigation - Electronics 5 01-03-2009 06:21 AM
Right side brake light and turn signal part number? danaM General Charger Discussion 1 02-10-2008 09:49 AM
Tinting Turn Signal: Removing the turn signal light! cofo Exterior Discussion/Modifications 4 02-23-2007 06:47 PM
You may post new threads
You may post replies
