inner tie rod replacement instructions - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 12 Old 04-29-2010, 11:33 AM Thread Starter
Shakin
Senior Member
Shakin's Avatar
(Thread Starter)
Hey folks, Ive been searching around, and have determined I need to replace my inner tie rods. Outers were done recently but I'm not paying any one to do this. I just need some instructions and a bottle of beer.
anyone know where i can find an exploded view or instructions for this job? Also any special tools needed?
thanks
2006 Charger R/T Black
Danko Reproductions Shaker Hood(Mopower),
JBA Catback,Headers,mids, 35% tint, honeycomb grille, chinspoiler, and rear diffuser, SC Tuner, Pioneer AVIC D3.
Shakin is offline
post #2 of 12 Old 04-29-2010, 12:11 PM
tlrpunk
Senior Member
tlrpunk's Avatar
Free bump, I'm interested in this as well.
20" Black Challenger replicas with Hankook Ventus ST RH06 275/40R20 tires - Pedders springs and shocks (shocks blew out after 30K miles, so KYB GR2 now) - Auto-headlight mod - 15% tint - SLP LMII w/Magnaflow resonators - Line-X grill - Bwoody endlinks
Front-end parts replaced: Tension struts (twice), inner & outer tie rods (twice), swaybar end links (twice), lower ball joints, struts (twice), shocks (twice), springs, sway bar bushings (twice), upper control arms, clunking again.
tlrpunk is offline
post #3 of 12 Old 05-01-2010, 08:42 AM
bronze
Member
okay not the answer you want to hear. after searching on Mitchell on demand. looks like the entire rack and pinion will need replacing if the inner tie rod is bad.
bronze is offline
post #4 of 12 Old 05-01-2010, 09:48 AM
Camsdad
Senior Member
Camsdad's Avatar
Quote:
This isnt the case. The inner tie rods are very replaceable without replacing the rack.
I don't have anything in front of me for wrench sizes needed at the moment so bear with me.
First lift up the car and use jack stands. Back the nut off where the inner and outer tie rod meet. I marked where the inner and outer met so that way I was relatively close when reinstalling. I measured the mark I put on the inner tierod and placed the mark on the replacement. You still should get an alignment afterwards. If your outer need replaced do it now with the inners. If not then leave the outers bolted to the knuckle. There is a flat spot on the inners to put a wrench too. Turn it to remove the inner rod from the outer rod. Then remove the boot. The small clamp just use pliers to crimp and slid off. The large one a small screw driver is needed. You can reuse the small one and also the large one if removed carefully. If not Napa or the dealer has a replacement. You will need to crimp it down during reinstall. Then put a wrench on the innser tie rod where it connects to the rack. It's pretty big. Remove it. Put locktite on the new tie rod and reinstall using the same procedure. I suggest getting torque specs on tighting the inner to the rack. I'm sorry I dont have them in front of me. Put grease on the iner tie rod end where the ball joint is for lubrication and to keep out moisture. Also put some on the boot ends to slide on easier. Put the retaining clips on the boot and put it on the rack and inner tie rod. Then using your measuerment on how far the outer tie rod was on the inner mark it and put the nut on it. Then put a wrench on the flat spot on the inner and thread it into the outer until you get to thea mark. Then make sure you tighten the nut to the outer tierod. Get an alignment. I wished it could me more detailed than this.
Camsdad is offline
post #5 of 12 Old 05-01-2010, 10:38 AM
slip
Senior Member
I copied the field service instructions to excel and posted a link here.
http://www.datafilehost.com/download-45ca463a.html
slip is offline
post #6 of 12 Old 05-01-2010, 02:20 PM
06-3.5L DCharger
Senior Member
06-3.5L DCharger's Avatar
I was able to change my inner tie rods with out doing the rack. Got inners outers by moogs
Preditor 93 Oct. tune K&N Cai,MagnaFlow Catback, Stainless Works Long Tube Headers with High Flow Cats, BND Aces IV and Quatum Blue, Shocker Train Horn, Getrag 3.73 LSD conversion kit,22 inch chrome Vipers
06-3.5L DCharger is offline
post #7 of 12 Old 05-01-2010, 08:37 PM
bronze
Member
mmm glad im wrong. did a quick search online. even went as far as Mitchell on demand for an hour and i came to that conclusion.
bronze is offline
post #8 of 12 Old 05-11-2010, 05:33 PM Thread Starter
Shakin
Senior Member
Shakin's Avatar
(Thread Starter)
sweet thanks!!
Shakin is offline
post #9 of 12 Old 05-11-2010, 06:13 PM
06-3.5L DCharger
Senior Member
thanks
You can also see vids of inner and outer and lower ball joints replacements on you tube
post #10 of 12 Old 05-11-2010, 06:30 PM
dejuan7
Senior Member
dejuan7's Avatar
I replaced my outers and most if not all of my clunk is gone.
GreenGoblin V6 to VVT 5.7 Hemi by PlumFlooredCreations
dejuan7 is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Gear in this thread - Powered by O'Reilly Auto Parts
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
help with tie rod end replacement! deltafrce General Charger Discussion 2 03-21-2010 11:17 AM
Tie rod ends scatpackmopar Wheels/Tires/Brakes/Suspension 3 08-31-2009 02:02 PM
Tie Rod Problem Goody625 Wheels/Tires/Brakes/Suspension 4 05-17-2008 01:26 AM
Tie rod/steering rack replacement Dutch General Charger Discussion 20 05-07-2008 12:49 AM
Bad tie rod! RB8484 Charger Problems/Assistance 0 03-11-2008 11:01 AM
You may post new threads
You may post replies
