Lower control arm ?'s - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 9 Old 04-12-2010, 03:27 PM Thread Starter
06-3.5L DCharger
Senior Member
06-3.5L DCharger's Avatar
(Thread Starter)
Hi,
I have a question. I just had my both front inner and out tie rods and both lower ball joints replaced yesterday with Moogs. Now when my friend was working on my charger he pointed out that the bushings for both sides of the lower control arms are shot.
Can I just buy the bushings and have them replaced or do I have to buy the whole new lower control arm for both sides?
I got a wheel alignment today. If I change the bushing or relpace the whole lower control arm will I have to get another wheel alignment?
Thanks
Preditor 93 Oct. tune K&N Cai,MagnaFlow Catback, Stainless Works Long Tube Headers with High Flow Cats, BND Aces IV and Quatum Blue, Shocker Train Horn, Getrag 3.73 LSD conversion kit,22 inch chrome Vipers
06-3.5L DCharger is offline
post #2 of 9 Old 04-12-2010, 05:16 PM
SJCHARGER
Senior Member
SJCHARGER's Avatar
The lower ball joint can be replaced, no need to buy the whole knuckle....
Write up for the install...
http://www.lxforums.com/board/showthread.php?t=198325
Where to get them...
RockAuto.com
Part #
K80996 MOOG non-adjustable lower ball joints
MOD LIST:TINTED WINDOWS 5% SO YOU CANT SEE UP IN MY WINDOWS, DUAL EXHAUST
FLOWMASTERS DELTA 40 SERIES SINGLE IN DUAL OUT WITH 3 1/2" TIPS, BODY COLORED AND TINTED TAILS, EAGLE EYE HEADLIGHT PROJECTORS, EIBACH PRO KIT, BT FRONT BADGE AND SHIFT INSERT, KONI SHOCKS AND STRUTS, DIABLO TUNED, BIG BULLY INTAKE....
SJCHARGER is offline
post #3 of 9 Old 04-12-2010, 05:40 PM Thread Starter
06-3.5L DCharger
Senior Member
(Thread Starter)
RockAuto.com
Part #
Im sorry I made a mistake its the tension strut that I need to change the bushing on
found a pic
# 30 in this pic
bottom left pic in diagram
Can I just change the bushing?
Do I have to buy the whole tension strut?
Do they also sell the ball joint for the tension strut?
Thanks for your help
post #4 of 9 Old 04-12-2010, 06:16 PM
SJCHARGER
Senior Member
SJCHARGER's Avatar
Quote:
Originally Posted by 06-3.5L DCharger View Post
I'm sorry I made a mistake its the tension strut that I need to change the bushing on
found a pic
# 30 in this pic
I can't find just the bushing for the tension strut. I think you might have to replace the whole piece. Their 58.79 a piece for the left or right side which is not bad, thinking about how much work it would take to pop the ball joint loose from the tension strut to get the bushing out....
Here are the part numbers from Rockauto....
Right side:
MEVOTECH Part # MS25121
Left side:
MEVOTECH Part # MS25120
Hope this helps...
post #5 of 9 Old 04-12-2010, 07:34 PM Thread Starter
06-3.5L DCharger
Senior Member
(Thread Starter)
RockAuto.com
Part #
I just got the lower ball joint both in the front replaced with moogs
Right side:
Left side:
Hope this helps...
Perfect thanks. Now when changing these, the tension struts do I need to get another alignment again?
Thank you
post #6 of 9 Old 04-12-2010, 08:02 PM
Manicmechanic
Senior Member
Manicmechanic's Avatar
Garage
Are you talking about this?
http://www.trademotion.com/partlocat...layCatalogid=2
Not sure about an alignment, maybe someone else can help?
2006 Torred Daytona # 1988 Tunable 2-3/4 Exhaust,Remote 996XT GPS Scanner, SRT Wheels/Legmaker modded, BC Racing Coilovers, Demon Eyes Front/Rear, Silverstars, V-1 Hardwired, SRT Brakes, RK Sport Hood. PaddleShifters, '09 MYGIG, LUKAS Ace Blackbox, I still open the car door for my Wife, so she doesn't scratch the paint with her nails!
Manicmechanic is offline
post #7 of 9 Old 04-12-2010, 08:26 PM
peachgary
Member
Thumbs down
this should will help
but you could talk to Mike at pedders.
plus this explains it http://www.peddersusa.com/products/19/153
peachgary is offline
post #8 of 9 Old 04-12-2010, 08:41 PM
peachgary
Member
just looked for EP6567 cant seem to find it on the site...
post #9 of 9 Old 04-12-2010, 09:12 PM
Samoan Tsunami
Senior Member
Samoan Tsunami's Avatar
anytime you change ANY major suspension compoment, you should always in the very least get an alignment check. usually most shops will run 20-30 dollars for this (which basically covers the time of putting the car on the rack and the laser guides on the wheels)...
Why sit around and watch everyone else live YOUR dream?
Samoan Tsunami is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
lower control arm bushings...i need help!!1 chargerboy04 General Charger Discussion 12 05-14-2009 08:26 AM
AWD lower control arm bushing concerns info@PeddersUSA.com Wheels/Tires/Brakes/Suspension 1 09-30-2008 10:35 PM
KDWS,lower control arm,washer bottle,3 18"r/t wheels,grill,passenger strut tower KY hemi RT Parts For Sale/Wanted 10 03-23-2008 02:48 PM
control arm bolt grinded down??? xslim502x Wheels/Tires/Brakes/Suspension 6 02-19-2008 07:41 PM
You may post new threads
You may post replies
