Check engine light is on - Dodge Charger Forums
Performance Discussion/Modifications Discuss any performance modification in this section.
post #1 of 128 Old 04-22-2006, 09:30 AM Thread Starter
AB Charger
Senior Member
AB Charger's Avatar
(Thread Starter)
There I was, cruising with my new mods installed, enjoying the throaty rumble of the JBA headers and catbacks, when all of a sudden, I hear a "ding". I look at my instrument panel and the Check Engine light is illuminated. I had travelled about 60 miles in total when that unwelcomed light turned on. What the heck is that all about? I called the shop that installed the system and they are not open agian until Monday. Suggestions?
2008 Light Greystone Pearl
Turbo Diesel GC
MODS:3M & 'Flaps
AB Charger is offline
post #2 of 128 Old 04-22-2006, 09:33 AM
Zoner
Senior Member
Zoner's Avatar
Re: Check engine light is on
Damaged O2 sensor or loose gas cap???
_______________
2006 Silver SRT8 - Options I, II, Bags, Roof
K&N Drop in Air Filter...
Jet Stage II...
Magnaflow Hiflow Cats...
Magnaflow Cat-back...
Zoner is offline
post #3 of 128 Old 04-22-2006, 09:44 AM
maneval69
Senior Member
maneval69's Avatar
toggle the key between off and on with out starting three times and the EVIC will show you the code.
It may be a loose gas cap.
2006 Charger R/T with Perf. Group Mods: Dynatech Coated headers & cats installed, Bassani cat-back, Superchips Flashpaq, Videos
maneval69 is offline
post #4 of 128 Old 04-22-2006, 11:23 AM Thread Starter
AB Charger
Senior Member
AB Charger's Avatar
(Thread Starter)
Checked the cap... it was tight. Did the ignition 3 times on and off thing and didn't see any "code" in the EVIC. BUT.. I did notice the EVIC displaying an ever increasing fuel consumption ratio, while the car was idling, staionary in my garage. When I turned the engine off, it was up to 60.9 litres per 100 km. When the engine was off, it was still climbing. What does that mean? Other than something is FUBAR.
post #5 of 128 Old 04-22-2006, 11:29 AM
GLHS837
Super Moderator
GLHS837's Avatar
You might not have done the key thing right. ON equals just far enough that the warning indicators come on. OFF equals just far enough back that they all go off. This must be done quickly, 3-4 seconds. Start with the key OFF.
1. Key ON
2. Key OFF
3. Key ON
4. Key OFF
5. Key ON and wait a few seconds.
Down in the EVIC, you should see either a code like P0300 (not that one, thats a multi cylinder misfire code) but a letter and four numbers.
Or, you could see dONE. But, if you do it right, you WILL see something.
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #6 of 128 Old 04-22-2006, 11:32 AM
maneval69
Senior Member
maneval69's Avatar
That's a good one,
I have no Idea.
post #7 of 128 Old 04-22-2006, 11:35 AM
maneval69
Senior Member
maneval69's Avatar
Quote:
1. Key ON
2. Key OFF
3. Key ON
4. Key OFF
Good point, if done correctly it will display "-------" for a few seconds and then "--done--" if there are no codes.
post #8 of 128 Old 04-22-2006, 11:49 AM Thread Starter
AB Charger
Senior Member
AB Charger's Avatar
(Thread Starter)
1. Key ON
2. Key OFF
3. Key ON
4. Key OFF
Well, after about 10 tries, the odometer went to dotted lines and this appeared. P0420. thanks GLHS for your help. NOw if I can just decipher what that means?
post #9 of 128 Old 04-22-2006, 11:58 AM
Crow
Senior Member
Thats an O2 sensor fault. Not sure which side. I think 420 is passenger side, 430 is driver side
Crow is offline
post #10 of 128 Old 04-22-2006, 12:35 PM
banana man
Senior Member
banana man's Avatar
bad o2 = bad gas milage
banana man is offline
  Dodge Charger Forums > Dodge Charger Discussion > Performance Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
check engine light came on slick V6 Specific Discussion 6 07-14-2008 06:23 PM
check engine light carcharger Charger Problems/Assistance 8 06-03-2006 02:22 PM
check engine light hitman Charger Problems/Assistance 10 03-07-2006 10:01 AM
Check Engine Light MANGOROB Charger Problems/Assistance 6 03-04-2006 09:17 AM
Check engine light BLUCHARGER General Charger Discussion 3 11-20-2005 10:28 PM
You may post new threads
You may post replies
