Engine light, and oil light - Dodge Charger Forums
post #1 of 24 Old 01-09-2010, 03:30 PM Thread Starter
BOSSMAN2677
Junior Member
(Thread Starter)
Hello, New to this forum. I have an 06 5.7. Two days ago the engine lite comes on. I had already planned an oil change, so we had it done yesterday (Fri), hoping the lite would turn off. It didnt, and now when I come to a stop, my oil lite goes on. Oil pressure dropped to 0 while at a stop lite. I found this forum yesterday, ran a diagnostic and got codes--P1521 (wrong oil?), its not, and P0520 Oil pressure switch. WHen in neutral, Pushing the gas, the oil pressure goes up. Let off gas and it goes back down. Would this be the sensor, or oil pump, not pumping? Is this something I can fix, or should I just take it to the Dodge stealer? ANy help would be appreciated
thanks Chris
BOSSMAN2677 is offline
post #2 of 24 Old 01-09-2010, 03:34 PM
Gabe
Senior Member
Gabe's Avatar
Quote:
thanks Chris
Could be the pump ...
What oil do you use ? 5w20 ?
Mine: '13 Mustang GT, Sterling Gray, 6-spd man, Recaros, Track Pk, 2.3L Whipple, 608 RWHP, 517 RWTQ
Fiancee's: '08 Mustang GT500, White/blue stripes, '13 TVS & injectors, FRPP twin-65mm TB, JLT 123mm CAI, 656 RWHP, 661 RWTQ
Previous: '07 Charger R/T AWD, heads/cam, a few other things. 355 AWHP, 370 AWTQ
Gabe is offline
post #3 of 24 Old 01-09-2010, 03:39 PM Thread Starter
BOSSMAN2677
Junior Member
(Thread Starter)
Yes, 5/20. At least thats what the receipt said. My wife took it in. Any way to tell for sure? Pump or sensor?
post #4 of 24 Old 01-09-2010, 03:44 PM
Gabe
Senior Member
Gabe's Avatar
If the lights came on right after the oil change, then they used the wrong oil and charged out on the ticket the correct type.
If you have a Predator you can try shutting off the MDS and see if the problem is still there .... if it goes away, then you definitely have the wrong oil, as the MDS system requires 5w20 oil to operate.
Gabe is offline
post #5 of 24 Old 01-09-2010, 04:00 PM Thread Starter
BOSSMAN2677
Junior Member
(Thread Starter)
No Predator. The car is stock. Would the wrong oil affect the pressure sensor, also?
post #6 of 24 Old 01-09-2010, 06:04 PM
AKCallahan
Senior Member
AKCallahan's Avatar
IMO..sensor
Tank: 2006 Dodge Charger V8 Hemi 5.7L R/T R&T
Twitch: 2006 Dodge Ram 1500 Laramie Edition 4x4 5.7L HEMI
AKCallahan is offline
post #7 of 24 Old 01-09-2010, 11:08 PM
rodneyiii
Senior Member
rodneyiii's Avatar
Quote:
Bossman mentioned in the original post that the engine light came on a day before the oil change so something else may be wrong. One way to know what is happening is to have the oil pressure checked using a mechanical pressure gauge. Since you have to remove the pressure sensor to do this, you might as well have a replacement sensor available to stick in if the mech gauge reading is OK.
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
rodneyiii is offline
post #8 of 24 Old 01-10-2010, 11:53 AM Thread Starter
BOSSMAN2677
Junior Member
(Thread Starter)
Thanks for everybodys replies. Its my wifes car, and I am getting the whole story in bits and pieces. I overheard her telling someone that both lights came on Before the oil change. I am going to replace the sensor, and have the pressure checked. Then we will see. I will repost my findings.
thanks Chris
post #9 of 24 Old 01-11-2010, 11:53 AM Thread Starter
BOSSMAN2677
Junior Member
(Thread Starter)
All fixed, it was the sensor. Aparently the Chargers dont like the elusive Cold weather that we are having here in SW Florida. Mec. said that he has seen alot of the sensors going bad due to the weather. $180.00 later all is well. Thanks for everyones help.
Chris
post #10 of 24 Old 01-21-2011, 10:02 PM
BlueKnights
Senior Member
BlueKnights's Avatar
I got the p0520 code a couple days ago, second time in 6 months. 1st time they changed the sensor, reflashed everything, then changed my oil without my permission. 6000 miles later, 2000 of which is on a fresh RP oil change, I get the code again.
Any ideas, at 98,000 miles?
Loaded ManGo! Royal Purple, 20% tint, Rain-X Repel, Streetglow LED, Billet Tech, Reflective Concepts, LMCW, Falken, R1 Concepts, Gorilla, K&N. Keep her clean, and ROLL.
BlueKnights is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Change Oil Light jamin19 Audio - Alarms - Navigation - Electronics 21 01-30-2015 10:33 PM
Check engine light and slight sparatic idle and ETC light. redirwol1 Charger Problems/Assistance 17 01-13-2014 01:48 PM
Low Oil Pressure at idle, oil light comes on too danaM Charger Problems/Assistance 48 12-05-2012 06:51 PM
Oil change soon.. Engine light? USMC_PETE Charger Problems/Assistance 3 01-07-2010 08:49 AM
Check engine light, slight sporatic idle with ETC light and it gets worse!! redirwol1 Charger Problems/Assistance 0 09-25-2009 12:25 PM
You may post new threads
You may post replies
