Odd noise at idle and after engine shut off... - Dodge Charger Forums
post #1 of 9 Old 12-05-2009, 12:23 PM Thread Starter
WhiteR/T07
Senior Member
WhiteR/T07's Avatar
(Thread Starter)
ok guys this one stumps me...I have a very high pitched noise coming from the engine bay at idle and when the engine is cut off..when I cut it off you can hear it directly from the engine bay then after a minute or so it fades away...I can not for the life of me think what it is..can anyone help?
07' StoneWhite R/T - 418 hp/413 tq CMR Tuned by HHP - 12.4 sec 1/4 mile 1.66 60' - Inertia Big Valve Heads, SRT MAX cam, 85 MM TB, SLP Underdrive pulley, Corsa, Kooks LT, AFE Stage 2 CAI, Pedderized, 180 T-stat, BT Catch Can, PI 2800 TC, Paramount Valve Body, Chubby Pro Sways, Getrag 3.06
WhiteR/T07 is offline
post #2 of 9 Old 12-05-2009, 12:27 PM
meglioed
Senior Member
meglioed's Avatar
Does it sound like its coming from an idler or tensioner pulley? Does it go away when you rev the engine?
2006 R/T....Ram Air Hood...CAI..Dynomax Mufflers..Flashpaq..180 Tstat...FlashTech Amber Halo's. Royal Purple. Traded.
2011 Jeep Wrangler....mods to come. Traded.
2009 Dodge Challenger R/T Classic, Track Pack, 6 Speed Manual, 3.92 rear gear, 20's polished, Leather....
meglioed is offline
post #3 of 9 Old 12-05-2009, 12:30 PM
370 HEMI
Supporting Vendor
370 HEMI's Avatar
It could be a high pressure leak that is whistling. When you shut off the engine, the pressure has to leak down and whistle away until equalized.....which then would make it stop.
Good luck!
Brian
More Power, More Torque, Better MPGs - It's "Rocket Fuel For Your Car"
Custom Designed & Custom Blended "ALWAYS beats off the shelf brands"
Better cooling, better protection without all "The Gunk"
370 HEMI is offline
post #4 of 9 Old 12-05-2009, 01:48 PM Thread Starter
WhiteR/T07
Senior Member
WhiteR/T07's Avatar
(Thread Starter)
where could the high pressure be coming from? im at a loss..I know its not a pulley or anything because it doesnt speed up or go away when uping the RPMs
post #5 of 9 Old 12-05-2009, 03:34 PM
meglioed
Senior Member
meglioed's Avatar
Most pulley or belt noises wont go away with rpm increase. Some will be louder while others might make a different pitch. Im not sure what kind of high pressure would encounter. Might be a vacuum leak.
meglioed is offline
post #6 of 9 Old 12-05-2009, 03:42 PM Thread Starter
WhiteR/T07
Senior Member
WhiteR/T07's Avatar
(Thread Starter)
hmm ima have to take a closer looks see if any vacuum lines are loose only reason i dont think its a belt or pulley is because it keeps going after the engine is cut-off. thats why pressure release sounds more like it..
post #7 of 9 Old 12-05-2009, 04:58 PM
juanitorus
Supporting Member (Lifetime)
juanitorus's Avatar
is your a/c on. try turning off that system to isolate your problem.
GOMANGO: 2197 0f 4000
Just a "Dope on a Rope" playin Army!!!
juanitorus is offline
post #8 of 9 Old 12-05-2009, 11:27 PM Thread Starter
WhiteR/T07
Senior Member
WhiteR/T07's Avatar
(Thread Starter)
a/c hasnt been on for awhile mainly heat
post #9 of 9 Old 12-06-2009, 01:46 PM
4FishLimit
Senior Member
Cooling fan?
2009 Stone White R/T-Painted Calipers,MOPAR CAI,Tint,Stripes by RiderGraphix,Daytona Spoiler, Eibach Pro-Kit
1986 Pontiac Trans Am- 305 TPI, 700R4, Factory WS6 Car, 100K on the clock, Far From Stock
4FishLimit is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Engine clicking noise from engine bay while idle.... Morb1ous Charger Problems/Assistance 15 07-01-2009 06:38 PM
engine idle noise through the speakers.... lilcmtz Audio - Alarms - Navigation - Electronics 3 11-17-2008 08:18 PM
Odd Transmission noise SRT8_in_CT Charger SRT-8 Discussion 13 09-13-2008 08:41 AM
Odd noise at start-up Crazy J General Charger Discussion 6 12-23-2007 06:58 PM
Odd noise from front suspension Lon Charger Problems/Assistance 25 03-15-2007 10:21 AM
You may post new threads
You may post replies
