Noise when turning Steering Wheel - Dodge Charger Forums
post #1 of 3 Old 12-02-2009, 05:15 AM Thread Starter
Kadgarth
Junior Member
(Thread Starter)
I tried searching both this forum and google and couldn't find anything conclusive.
Sometimes when I turn my steering wheel (seemingly more often than not in the morning when its a bit chilly) it will make a strange noise. The noise eminates from the back of the wheel. Its a low noise that is similar to dragging an eraser across a table (best I could come up with :P ).
Any ideas?
Kadgarth is offline
post #2 of 3 Old 12-02-2009, 05:40 AM
370 HEMI
Supporting Vendor
370 HEMI's Avatar
Any ideas?
Sounds like the internal friction of the rack and pinion when it is cold that is telegraphing up the shaft and you are hearing/feeling it through the steering wheel causing a resonation like an eraser on the table.
Many on this forum have had this situation, and have used the QuantumBlue Steering System Lubricant Catalyst that you can add to the reservoir (2 oz per system) which will permanently lubricate the centering bushing, condition the outer cup seals, and the spool valve seals that are made of PTFE....or as some know as Teflon (R). Comes in a 6 oz bottle (3 treatments) for $12.99. One of the best and easiest fixes for these cars.
The moan that comes from the pump when turning is eliminated as well. Here is a link to explain more.
http://www.bndautomotive.com/page/page/931789.htm
Regards,
Brian
BND Automotive LLC
440-821-9040
More Power, More Torque, Better MPGs - It's "Rocket Fuel For Your Car"
Custom Designed & Custom Blended "ALWAYS beats off the shelf brands"
Better cooling, better protection without all "The Gunk"
370 HEMI is offline
post #3 of 3 Old 12-02-2009, 07:06 AM
kensreddaytona
Senior Member
I have the same noise in the morning but I believe it's coming from the steering wheel itself, goes away after awhile.
kensreddaytona is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Squeek when turning the steering wheel relltherell Charger Problems/Assistance 10 01-26-2010 06:13 PM
Weird noise while braking and turning Tyrant Charger Problems/Assistance 2 04-07-2009 06:09 PM
Steering wheel noise aver2869 Charger Problems/Assistance 2 03-12-2009 11:30 AM
Noise when turning. mluker Off-Topic 1 11-22-2007 11:16 AM
Steering wheel clunking noise spongebobhemipants Charger Problems/Assistance 4 07-15-2006 01:12 PM
You may post new threads
You may post replies
