Radiator drain location? - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 11-21-2009, 10:26 AM
dodgetimes2's Avatar
dodgetimes2 dodgetimes2 is offline
Senior Member
Hoping somebody can help quick as I'm short on time. I can't seem to figure out how to drain the coolant on my Daytona. I have all the underbody plastic pieces off and have found what i believe is the radiator petcock. I've turned the petcock to the open position and nothing happens. I've also taken off the small length of drain hose to make sure that wasn't plugged. Is there a chance the petcock is plugged? Or is there a drain bolt somewhere? Thanks.
__________________
2006 Go Man Go Daytona #2441 - 20" American Racing Torq Thurst Wheels, AFE Stage 2 CAI, SLP Loudmouth 1 exhaust, Diablo Predator, DIY trunk lid liner, 22elite console cover with embroidery by Jina, visor desguisers by streamlinedesign, glovebox light mod, hood prop mod
1999 Dodge Ram 1500 QuadCab 4x4, 6" Skyjacker suspension lift, 3" PA body lift, 38" SuperSwamper SSR tires, 16"x10" Helo Maxx 6 wheels, nerf bars
2007 Dodge Ram 1500 QuadCab 4x4, stock for now other than nerf bars
  #2
Old 11-21-2009, 12:55 PM
wickedchargerrt's Avatar
wickedchargerrt wickedchargerrt is offline
Banned User
bottom right of the radiator as your looking at it from underneath
  #3
Old 11-21-2009, 06:23 PM
Senior Member
Still couldn't find the damn thing. I have opened the petcock 90 degrees and nothing happens. I've attached pictures of the petcock location (yes, it's on the bottom passenger side). I have the service manual and it states there is a drain bolt but the diagram shown is not very good.
ID:	50277   Click image for larger version
ID:	50278   Click image for larger version
__________________
  #4
Old 11-21-2009, 06:56 PM
1FST4DR 1FST4DR is offline
Senior Member
Thats it bud.Twist and pull
__________________
06 BLK charger SRT-8.
10.06@137mph
a few Mods...
www.custombilletstore.com
  #5
Old 11-21-2009, 07:18 PM
Senior Member
Twist and pull!! You figure the damn 1000 page service manual would tell you that. I'll give it a shot tomorrow, ran out of daylight. Thanks!
__________________
  #6
Old 11-22-2009, 09:29 AM
TBird100636's Avatar
TBird100636 TBird100636 is online now
Senior Member
My Charger: 2011 Charger R/T Plus AWD
Exclamation
Quote:
You have to turn the petcock more than 90 * and gently pull out while turning to get it to drain.
__________________
2011 Dodge Charger R/T Plus AWD- Redline-5.7L Hemi Registry #1650 Tbird100636
2006 Dodge Charger R/T- Inferno Red- Gone-5.7L Hemi Registry # 00696 Tbird100636
  #7
Old 11-22-2009, 10:25 AM
ChargerS.X.T's Avatar
ChargerS.X.T ChargerS.X.T is offline
Senior Member
I am not sure if this true but I read this while reading about coolant flush:
If you are doing a backyard "coolant flush" (you are trying to get ALL the old stuff out) then you should realize it is virtually impossible to get all the old coolant out of your cooling system. Even when the radiator is completely drained there is still usually about half of the total system capacity of coolant left in your engine block. The only good way to get this all out is to take it to a professional that has a coolant flush machine.
If Wicked could tell us if most dealerships use these machines and if he recommends this instead of changing it ourselves.
  #8
Old 11-22-2009, 01:18 PM
Senior Member
Well there are a few tricks to avoid running the car to the dealer/Mechanic.
You can remove the Thermostat and use a air hose and force the coolant out.
Just a suggestion
__________________
10.06@137mph
a few Mods...
  #9
Old 11-23-2009, 11:51 AM
Senior Member
Twist and pull and twist. That did the trick. Thanks again.
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Anyone ever have this happen? upper radiator hose came off of the radiator nofear18 Charger Problems/Assistance 5 11-04-2009 05:37 AM
Anyone have this Drain Plug Hemidude23 General Charger Discussion 29 01-19-2009 01:14 AM
Rounded drain plug! chris shades Charger Problems/Assistance 21 10-16-2008 06:11 PM
Oil Drain Valve TopBanana_102 New England Area 11 06-14-2007 07:09 PM
3.5L transmission has a drain plug? high888 V6 Specific Discussion 2 08-07-2006 11:13 PM
© AutoGuide
