Ride Height and lowering an R/T AWD - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 17 Old 11-02-2009, 07:32 AM Thread Starter
Rob440Magnum
Senior Member
(Thread Starter)
Does the R/T AWD have a higher ride height than the rear wheel drive R/T. How about compared to the SRT8?
What parts need to be purchased to lower the ride height, aprrox. cost and where did you buy the parts?
How many hours of labor is involved with lowering the car?
How did lowering the car change the quality of the ride as far as handling and going over bumps.
Thanks, Rob
Rob440Magnum is offline
post #2 of 17 Old 11-04-2009, 06:03 PM Thread Starter
Rob440Magnum
Senior Member
(Thread Starter)
Anyone out there? Can anyone at least answer these two questions below:
Does the R/T AWD have a higher ride height than the rear wheel drive R/T?
How did lowering the car change the quality of the ride as far as handling and going over bumps?
post #3 of 17 Old 11-04-2009, 08:34 PM
Gabe
Senior Member
Gabe's Avatar
I had Eibach springs (part # 2879.140 - a set for sale currently in the Active Threads ) installed when the car was about 3 months old .... they made the ride a little firmer, made the cornering a lot flatter, and gave me the look I was after
Yes, the AWD sits about 1" higher than a corresponding RWD model ... the extra fender gap looked horrible in my eyes and I had to do something about it as soon as I could
The SRT8 model sits another 1" lower than regular RWD models.
There's a member, on lxforums I think, that is using SRT8 springs on his AWD and it looks awesome.
There is also a coil-over kit available from KW, and another coil-over kit coming from Circuit Motorsports - a vendor on that other site
Hope I helped - I just saw this thread.
Also, click on the "my mods" link in my sig and you'll see all kinds of pics before and after the lowering
Mine: '13 Mustang GT, Sterling Gray, 6-spd man, Recaros, Track Pk, 2.3L Whipple, 608 RWHP, 517 RWTQ
Fiancee's: '08 Mustang GT500, White/blue stripes, '13 TVS & injectors, FRPP twin-65mm TB, JLT 123mm CAI, 656 RWHP, 661 RWTQ
Previous: '07 Charger R/T AWD, heads/cam, a few other things. 355 AWHP, 370 AWTQ
Gabe is offline
post #4 of 17 Old 11-04-2009, 10:21 PM Thread Starter
Rob440Magnum
Senior Member
(Thread Starter)
Yes that helps alot Gabe!
If I put 255/45R20 Goodyear RSA tires all the way around that will close up 1/2" of the space in the wheel well correct? Will I have any rubbing or clearance issues with that size tire?
Secondly, is there anything that can be done when lowering the car to keep the ride comfort there. This is my wife's car and I do not want driving over the bumps to be more harsh or noticeable. Any advice there?
Thanks, Rob
post #5 of 17 Old 11-05-2009, 04:10 AM
Gabe
Senior Member
Gabe's Avatar
Thanks, Rob
Well, the rear springs on the AWD are the same springs normally used on the RWD, they're even labeled "RWD" and they use a spacer to bring the ride up.
In the front there are different springs altogether, but using the stock RWD springs could probably work ... this should bring the ride height to stock-RWD height ...
The 255/45R20 tire size is 29" tall and the OEM 225/60R18 size calculates to 28.6" tall, but only half that difference would be added to veh height or fender gap ... so 0.2" would be hardly noticeable ... the 255/45R20 is the size I was using on my summer 20's .... 20x8 rims with 50mm offset ... no rubbing, no problems
Here's some pics of that fitment :
And a pic showing my ride height before and after the Eibach spring install :
Gabe is offline
post #6 of 17 Old 11-05-2009, 06:53 PM Thread Starter
Rob440Magnum
Senior Member
(Thread Starter)
Hi Gabe,
What if I also change the Charger R/T AWD shocks to the SRT8 Bilstein Front and Rear Shocks along with the Eibach springs? What will that do for me versus just changing the springs?
Secondly, do you know if the Challenger SRT8 Bilstein Front and Rear Shocks will work on the Charger R/T AWD?
Thanks for your help! Rob
post #7 of 17 Old 11-05-2009, 06:57 PM Thread Starter
Rob440Magnum
Senior Member
(Thread Starter)
[QUOTE=AWD_Gabe;1936194]Well, the rear springs on the AWD are the same springs normally used on the RWD, they're even labeled "RWD" and they use a spacer to bring the ride up.
QUOTE]
How easy is it to remove the spacer to get the rear to the stock R/T non-AWD height?
The front of the car would still be 1" higher than the R/T non-AWD, correct?
Thanks, Rob
post #8 of 17 Old 11-05-2009, 08:46 PM
Gabe
Senior Member
Gabe's Avatar
The front struts are different on the AWD ... the lower part has a fork that the axle shaft goes through ...
So you may be able to use the RWD stuff for the rear, but in the front, you've got limited strut options (KW and the upcoming Circuit Motorsports stuff)
Pedders teased us a while back but decided to flip-off the AWD owners and leave us hanging ...
Gabe is offline
post #9 of 17 Old 10-03-2010, 07:30 PM
Azurden
Member
EiBach Springs
Just did the lower job on my AWD R/T using the EiBach 300 sprint kit #2879.140. All went well. Not install issues and dropped the ride around 1.5 in which I would say is plenty for this car. Love the looks... Even more sporty. Have not even taken it out yet to see how it rides, gonna take a break and enjoy the looks for a bit.
I would say that AWDGabe was right on about the springs. Other full kits can run up to $1000 but if you looking to do an upgrade on the cheap. EiBack spring kit did the trick... Oh, fyi. I called Eibach to see if they had a specif spring kit for the AWD R/T... Reply... No... And no reason given. I asked about using the 300 springs and they said it was up to me, but they will not say it will work. For those of you who worry as much as I do, don't the 300 spring work fine...
Here is a pict of the rear done and the front not... You can really see the difference in this pict.
Az
08 R/T AWD with XXR 20's Black, Custom Hood, Graphics, Chin, SLP Loudmouth I,
Azurden is offline
post #10 of 17 Old 10-26-2010, 06:46 PM
DecepticonLockdown
Senior Member
DecepticonLockdown's Avatar
Hey AWD Gabe, where did u get those awesome rims?!?!?!
2013 Dodge Charger SRT8
DecepticonLockdown is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Stock RT Ride Height Adjustable? dstrand25 Wheels/Tires/Brakes/Suspension 1 09-16-2009 10:11 PM
AWD Ride Height vrykeen Wheels/Tires/Brakes/Suspension 10 11-12-2007 11:36 AM
lower ride height? J Rock Charger SRT-8 Discussion 2 11-01-2007 12:22 PM
AWD RT suspension height Gabe Wheels/Tires/Brakes/Suspension 2 06-05-2007 01:34 PM
Ride height oddity Darnice Charger SRT-8 Discussion 16 12-20-2006 07:29 PM
You may post new threads
You may post replies
