Opinions please..2.7L with low oil pressure - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 1 Old 10-20-2009, 03:28 PM Thread Starter
chargersocal
Member
chargersocal's Avatar
(Thread Starter)
Hey everyone, I'll try to make this as short as possible. I've had an ongoing propblem with oil light coming on when I come to a stop and then turning back off when I excelerate. About six months ago I had the oil pressure switch changed and all seemed good until recently. The warning light started again. I brought it into another mechanic and this time he ran an oil pressure check and changed the switch again.
This mechanic indicated that a 2.7 L engine at idle oil pressure at minimum should be 5 psi and mine is about 4.5 psi. No big deal I thought. Although at 3,000 rpm it should be 45-105 psi where as mine is 25 psi. This mechanic mentioned that the engine sounded strange and there was a knocking noise. From reading on the forums I have heard that the 2.7L engine does in fact have a rough idle. Anyways, He stated he felt that it could be an internal engine problem that could be very expensive. My charger only has 55,000 miles on it and this worries me. I did ask if he checked the oil pump and oil screen which he said he did not.
I am seriously considering trading in my car before a serious problem occurs. I would like others opinions if the oil pump and oil screen could be likely culprits and a not to expensive fix. I really like my charger but do not want to be left with a great looking car with a blown engine. Thanks in advance everyone.
06 Charger SE Black pearl, 20" Black GTP niche rims, LED interior lights and Navigation, parrot handsfree device and Eibach pro-kit, Blastin Bob's dual 3.5 pipes
chargersocal is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Gear in this thread - Powered by O'Reilly Auto Parts
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Low Oil Pressure at idle, oil light comes on too danaM Charger Problems/Assistance 48 12-05-2012 06:51 PM
Crap!,I need some opinions here on my low oil encounter ReadDealONeil Charger SRT-8 Discussion 1 08-27-2007 12:33 PM
low oil pressure @ idle rogerc5 Charger Problems/Assistance 29 04-16-2007 10:49 PM
Normal low idle oil pressure?? Pontiac_convert Charger Problems/Assistance 18 07-21-2006 06:53 AM
Low tire pressure light reddawgfuji Charger Problems/Assistance 28 12-09-2005 04:37 PM
You may post new threads
You may post replies
