Speedometer not working - Dodge Charger Forums
post #1 of 9 Old 10-15-2009, 01:51 PM Thread Starter
icecreamhemi
Junior Member
(Thread Starter)
I have an 06 charger rt. The speedometer stopped working. Does anyone know what could cause this problem? The dealer says the instrument cluster is bad, but everything on the cluster is working except for the speed. I need a second opinion before I spend $300 on a new cluster.
icecreamhemi is offline
post #2 of 9 Old 10-15-2009, 08:03 PM
rodneyiii
Senior Member
rodneyiii's Avatar
Quote:
The analog gauge might have gone bad. I don't think the car knows if that needle stops working so it wouldn't throw a code. If the speed sensor went out, you would know for sure with a code. Try this cluster test:
Cluster diagnostic.
Press and hold the trip meter reset then turn the key to "ON", the gauges will step through the whole range. If your gauge is acting funny, this is an easy way to see if it's the sender or the gauge.
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
rodneyiii is offline
post #3 of 9 Old 10-16-2009, 09:56 AM Thread Starter
icecreamhemi
Junior Member
(Thread Starter)
I did the cluster diagnostic and the speedometer was the only gauge that didn't respond.
post #4 of 9 Old 10-16-2009, 10:04 AM
SVRSRTCDN
Senior Member
Sad to say then, looks like you need a cluster. You could try disconnecting the battery, wait a few min and reconnect. then try the cluster diagnostic again but i doubt it will help.
Returned 2006 Silver SRT8 (vanished into the unknown!)
2004 Jeep Grand Cherokee Overland
2012 Black Charger SRT8
SVRSRTCDN is offline
post #5 of 9 Old 11-26-2009, 05:54 AM
forumoto
Junior Member
Quote:
Cluster diagnostic.
Well I did this diag and my speedometer fead, it goes to 100+ then start to counts down as other clusters count down by jumping one, one one till it rest. please what is next as the speedometer needle read and comes down as the rest comes down. what should be check next
forumoto is offline
post #6 of 9 Old 11-26-2009, 07:35 AM
amont5
Junior Member
I had a problem with the speedo on a neon once, i tired to find the link but after everyone including the dealer told me i needed to replace i found a neon fourm that said to hold the trip reset button in then insert the key and cycle off to acc then on and back off. they speedo flung to 100 then rested back to 0 and worked like a charm from then on. dont know if this will work for you but worth a try. good luck
- edit just read the other post--- sorry
amont5 is offline
post #7 of 9 Old 11-26-2009, 12:35 PM
forumoto
Junior Member
I have done the above stated diagnoses and mine flung to 100 then to 0, yet still the speedometer can rise, i have the car raise up in the air while i do this as i am aware the rear pushes the car, so with the car being in air, and the tires rolling i expect to see the speedometer reading... please keep the suggestion coming
forumoto is offline
post #8 of 9 Old 11-26-2009, 12:48 PM
Vito
Senior Member
Vito's Avatar
Send a message via AIM to Vito
bring it to the dealer its probably just tripped
I really Hate Mustangs, Especially Cobras
True||Street||Cars
1000+ RWHP Twin Turbo SRT-8 In The Making
Vito is offline
post #9 of 9 Old 11-26-2009, 12:57 PM
forumoto
Junior Member
Tripped, come on i needed help that is why i am on here, i know there are dealership but i must get it through first
forumoto is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Metric Speedometer - where can I get a metric speedometer face? drjimmy General Charger Discussion 14 03-06-2008 04:07 PM
Speedometer? Phlipbak Wheels/Tires/Brakes/Suspension 1 03-05-2008 09:54 AM
MDS working / not working. Going to dealer PLUM CRZY 1074 Charger Problems/Assistance 8 02-15-2008 08:56 AM
speedometer cientifik12 Charger SRT-8 Discussion 2 11-19-2007 09:54 PM
Speedometer MexCharger Interior Discussion/Modifications 3 07-19-2007 06:25 PM
You may post new threads
You may post replies
