» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Please Visit our Site Sponsors
ChargerForums.com is the largest Dodge Charger Forum on the internet. Registered Users do not see the above ads.
Thread Tools Display Modes
  #41
Old 07-20-2009, 09:39 PM
topbanana3767's Avatar
topbanana3767 topbanana3767 is offline
Senior Member
Send a message via AIM to topbanana3767
im wondering on his a/f how the heck can it be 7.6 and not be completly bogged down ?
__________________
730hp@crank 610hp@wheels/426 hemi by inertia/supercharger/custom cam/kooks lt/kooks hiflow cats/b&b catback/1000hp half shafts/quafiee diff/front middle and rear strut bars/srt gears/challenger rims/predator/dvd/2800protq conv/srt brakes/srt hood/ported 6.1 manifold jethot coated/mopar 5.7 heads/srt radiator/catch can/cabin filter/killer daytona theme/tranny and engine coolers/msd coils/msd fuel pump/meth kit/mopar tcm/siemens 60lb injectors/driveshaft saftey loop/ati dampner/aeroforce and 2 a-f guage/cpr fuel rail w-xover/aac halos/walbro fuel pump/fuel psi guage/bnd quantum oils & fuels/psi valve springs/more to come/
  #42
Old 07-20-2009, 09:41 PM
mongoose57hemi mongoose57hemi is offline
Senior Member
Don't know but that's what she says during WOT.
  #43
Old 07-21-2009, 12:39 AM
dudeiwin86's Avatar
dudeiwin86 dudeiwin86 is offline
Senior Member
you have heads cam and a stall according to the vid.
makes your story a lot more believeable.
clearly you started yanking on him but not by much.
not bad
now fix your wideband
__________________
'06 Silver R/T R&T Fully Loaded
->FRI'd with Street/Strip Heads + Scud Camshaft<- CTP Spacers + 09 Eagle Manifold
-FRI Custom Stepped LT Headers--Getrag 3.06 LSD--DIABLOsport Predator--Powerbond 25% Underdrive Pulley--ProTorque 2800
-FRI PolyMounts--GSM Cold Air Intake--180Tstat--RTJunkieNOESP--MoparTCM--PEDDERS Touring Kit--Billet Tech Throttle Body
Best ET: 12.490 sec @ 113.58 mph +400 DA, 4000 RaceWeight
  #44
Old 07-21-2009, 12:50 AM
Senior Member
Yeah as of now I'm VERY biased toward the top end. I guess that's what 2.82s do to ya. That's why I do better from a roll cause I can sit at the top of first and plow through the gears. I think the roll race showed my power better. Now I need to get that chally rear end swap and throw some slicks on her and I'll be a lot better off from digs. I'm hoping they come out with 3.55s soon cause I think 3.73's would just make 1st and 2nd pointless.
  #45
Old 07-21-2009, 10:14 AM
dudeiwin86's Avatar
Senior Member
ummm..
if you get the chally rear rend you can choose: 3.06, 3.73, 3.92
3.73 and 3.92 are WAAAAY too much gear for a 5 speed car in my opinion.
i picked up the 229mm Getrag(chally) 3.06 and its a dream, power you can feel from the gear, and LSD which really helps traction by getting both wheels together too.
they wont have a 3.55 for that rear end any time soon, and id rather have a 3.23 instead anyway. infact something more like a 3.19 is THE GEAR for these cars if you ask me. between tire sizes and transmission gear, the 3.19 lets you size up tires perfectly for the 1/4 mile
to do a 3.55 you have to use a stock 210 or 215mm rear end and swap the ring and pinion with a richmond gear set.... but you still dont have an LSD
__________________
  #46
Old 07-21-2009, 11:21 AM
Senior Member
Thanks for the info. Ill most likely go the 3.06 route. Unless anybody has anything good to say about the 3.73s.
  #47
Old 07-21-2009, 11:23 AM
Senior Member
http://videos.streetfire.net/video/L...ger_696615.htm
Just thought I'd add the link here so you don't have to keep going back to the last page.
  #48
Old 07-21-2009, 09:32 PM
Toxie Toxie is offline
Senior Member
Quote:
Yeah as of now I'm VERY biased toward the top end. I guess that's what 2.82s do to ya.That's why I do better from a roll cause I can sit at the top of first and plow through the gears.
Huh? Those gears don't help you from a roll, unless you plan on going over 165 MPH, where a shorter geared vehicle will run out of gear and be physically limited by revs. Otherwise, the numerically higher rear gear will nearly always be faster (double so from a roll, since traction will not be an issue) since it trades top speed for torque multiplication.
Additionally, you need to pull your head out of the sand. You claim to beat him out by a car (video shows barely a fender), fair enough, then you go on to claim you "slaughtered him by 15 or 20 cars" and leave out that he misses a gear. That roll race din't show ANYTHING, since the gto driver obviously just threw in the towel after missing the gear.
I've got BOTH, and your smoking crack if you think that race would have been in any way susstantially different from the dig race.
Not exactly the most truthful race description I've ever heard. I'm with Grim on this one here - tell it like it was, not how you want it to be. Kaleb needs to learn how to drive better, for sure.
__________________
*2005 CGM M6 GTO*
Avic D3, Dashhawk, Pedders Street I w/ 1/2 drop rear springs, GMM Street, LPE CAI, FAST 92, 160* thermo, Vector HSRK, Kooks 1 3/4 w/ catted mids/Stainless Works X-pipe/catback. C5R Timing Chain, Monster Stg 5, FTI Cam 236/240 .615/.610 112LSA. Nitto 245/45/17 in the Rear. 3.91's and eaton diff incomin'
*2006 Charger R/T*
Inferno Red, Magnaflow 11385 muffler, C&L CAI. Butt Warmers FTW!
  #49
Old 07-21-2009, 09:50 PM
Senior Member
Whatever I won. You guys are still going to be dbags that's fine. And he started in first, hit second, and then in the end you see him flash his lights. That's when he "missed 3rd" Like I said, I told him I'd race again and he didn't want to. But keep on being asses I'm done with this ****ing forum. I apologized explained myself, and shown you a video. At the end of the first race we were still going and I got him by 1/2 to a car. Second race I clearly pull on him easy and he doesn't miss third till he flashes his lights. Watch it again. To those of you that aren't dbags on here I hope you enjoy your cars as much as I do. For the rest of you, go **** yourselves. Peace.
  #50
Old 07-22-2009, 11:24 AM
Grimlock Grimlock is offline
Senior Member
No loss. Cya!
__________________
Grimlock
2007 Charger SRT8 in TorRed
Pedders Track II Suspension, Pedders Xa Coil-Over Shocks, Dynomax Cat-Back, Quaife LSD, Predator w/SVS CMR Tune, Jet 180 T-Stat, and AFE Stage 2 CAI
1969 Roadrunner in TorRed Gone, but not forgotten! <beep, beep>
Thread Tools
You may not post new threads
You may not post replies
Similar Threads
Got a Goat, need a Charger. JMJ Charger SRT-8 Discussion 17 04-14-2008 07:03 AM
Daytona and Goat Aramis Picture/Media Post 18 03-15-2008 11:16 AM
charger R/T vs ls goat EvilGoat General Charger Discussion 67 09-26-2007 07:27 PM
Ran with a goat... ChargedUpInAZ General Charger Discussion 30 03-03-2006 10:16 AM
F@#K the GOAT!! RonRacer General Charger Discussion 50 01-14-2006 07:18 AM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin®. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© AutoGuide
