Warped r1 concept rotors - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 13 Old 06-23-2009, 06:41 PM Thread Starter
06InfernoRT
Member
06InfernoRT's Avatar
(Thread Starter)
I've had them installed for over a year now and for the last 2 weeks I've had brake issues. I took it into Dodge for the 60,000 service and had them check the brakes. I just got a call that the rotors are warped, GREATTT along with the water pump going out, a loose bolt in the rear end causing my ESP light to on and off and my broken sunglass holder which is a couple of pins ($5.00 part) but $175 to install. Almost $1100. for everything and they're not touching the brakes or the sunglass holder. The ESP and sunglass holder aren't covered under the warranty even though I have the "best" warranty. Has anybody else had rotor issues so long after they've been installed?
SRT Rear Spoiler, RK Ram Air Hood, 20" tires, 20" Maas rims, R1 Concepts slotted/drilled premium rotors, posi quiet ceramic pads, removed side moldings and hemi badges, C & L CAI
06InfernoRT is offline
post #2 of 13 Old 06-24-2009, 09:27 AM
ChargerOn22ss
Senior Member
ChargerOn22ss's Avatar
that doesnt sound good at all! I think I will be staying away from that brand of rotor now.
***Charger Sold, Now - Twin Turbo 335i
***Mods - 06 Charger R/T Silver Steel Metallic
5% Tint All Around, 22 inch Wingman Chrome Rims!! HID's Flashtech 6000K, Interior LED's, Debadged, Kenwood NAV, Modded Xbox, 400Watt Power Inverter, Black Grille, Honeycomb Grille, AFe Stage 2, Custom Stereo 2 12" Fi SSD Subs, 1200D Sundown Audio Amp
Future Mods -
Pay Mortgage
ChargerOn22ss is offline
post #3 of 13 Old 06-24-2009, 10:27 AM
DaBlackPearl
Senior Member
DaBlackPearl's Avatar
6 mnths wit R1 rotors and not a lick of trouble. sunglassholdr you can do yourself and the brakes. I assume that you don't have 60,000 on the R1's? Call Steve at R1 Concepts and see what kind of warranty you have on the rotors.
2007 SXT 3.5 V6 Brilliant Black Pearl Jack Sparrow Doesn't Live Here!
SRT Hood w/Scoop |~| Rear Spoiler |~| Smoked Taillights |~| Tinted Windows |~| K&N CAI |~| Custom Magnaflow Dual Exhaust |~| 20" Torque Thrust M Wheels & 245/45/20 Nitto Invo Tires |~| Blue LED's Under Dash |~| Blue LED's Inside |~| Blue LED Cup Holder Mod |~| 8000k HID - Lo's & Fog's |~| Mopower Deep Dish Grille |~| Mopower Chin Spoiler |~| R1 Slotted/Drilled Rotors |~| Carbon Pads
|~| Flashtech Rear Halos
|~| Hood Scoop LED Lighting |~| Flashtech Blue Head/Fog LED Halo's ~ KSport Springs 1.75 Drop
DaBlackPearl is offline
post #4 of 13 Old 06-24-2009, 10:36 AM
Lymzilla
Senior Member
I've had R1Concepts 'premium' rotors on my Daytona for over a year, and no warping. Just remember that many Service Center mechanics will use the 'warped rotor' excuse so they can replace rotors. Many times the problem IS NOT the rotors, just brake pads, or unbalanced or mis-aligned wheels/tires.
I would get a second opinion about those rotors before wasting money on another brand.
Lymzilla is offline
post #5 of 13 Old 06-24-2009, 10:58 AM
PlumCrazy1091
Senior Member
PlumCrazy1091's Avatar
Quote:
Sounds like you need to find a new mechanic.
Performance Mods: Corsa Exhaust, AFE Stage 2 CAI, Predator 93 CAI Tune, Razers Edge Front and Rear Strut Brace.
Body Mods: Mud Flaps, Hood Struts, Trunk Lid Cover, Sill Plates, Daytona Shift Plate.
Best 0-60 - 5.18
PlumCrazy1091 is offline
post #6 of 13 Old 06-24-2009, 11:03 AM
TripleTransAm
Senior Member
TripleTransAm's Avatar
Do your pads slide freely on their clips?
I just recently discovered how badly my caliper brackets were machined from factory, such that the pad ears tend to drag no matter how much lubricant you put on them. I'm thinking this may be a contributing factor to why some Charger owners have so many brake issues and others are fine.
In my case, I had to dremel down the pad ears very carefully to the point where they were snug and secure but move smoothly on the clips. For the first time in 3 years I don't have to fight with crazy pad dust every 2 weeks, although it's likely also going to cost me new rotors in the end.
/Steve
1987 Pontiac Trans Am GTA
1998 Pontiac Trans Am WS6
1978 Pontiac Trans Am
1978 Pontiac Trans Am 4-speed SE
2006 Daytona R/T Tor-Red (59 of 200 - Canadian)
2016 Dodge Charger R/T R&T
TripleTransAm is offline
post #7 of 13 Old 06-24-2009, 08:55 PM Thread Starter
06InfernoRT
Member
(Thread Starter)
That would be my first thought but he recommended not changing them since I had so much left on my pads.
post #8 of 13 Old 06-26-2009, 11:36 AM
SupremeG
Senior Member
SupremeG's Avatar
Hmm, I've had R1 slotted rotors for quite some time and haven't had any issues.
SupremeG is offline
post #9 of 13 Old 06-26-2009, 06:32 PM Thread Starter
06InfernoRT
Member
(Thread Starter)
It suprised me after putting so many miles on them (approx. 12-15K) I would have thought if the rotors were going to get warped it would have been alot sooner.
post #10 of 13 Old 06-26-2009, 06:49 PM
Gabe
Senior Member
Gabe's Avatar
In 24k miles I've manage to warp 2 sets of front OEM rotors, a set of slotted R1Concepts front rotors, and 2 sets of OEM rear rotors.
I'm now using R1Concepts slotted/drilled rotors all around - Steve warrantied the fronts for me and I bought the rears and new pads.
Mine were warped within about 8-10 months ... I forget exactly ...
Mine: '13 Mustang GT, Sterling Gray, 6-spd man, Recaros, Track Pk, 2.3L Whipple, 608 RWHP, 517 RWTQ
Fiancee's: '08 Mustang GT500, White/blue stripes, '13 TVS & injectors, FRPP twin-65mm TB, JLT 123mm CAI, 656 RWHP, 661 RWTQ
Previous: '07 Charger R/T AWD, heads/cam, a few other things. 355 AWHP, 370 AWTQ
Gabe is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Warped Rotors lammy Charger Problems/Assistance 9 03-06-2011 11:33 PM
Warped rotors.....AT 56 MILES! LeeR Charger Problems/Assistance 22 06-26-2009 09:59 PM
Rotors Warped need help!! ChargerSXT07 Charger Problems/Assistance 27 03-17-2009 01:21 AM
R1 Concepts rotors - one is warped 733subvet Wheels/Tires/Brakes/Suspension 13 03-20-2008 10:36 AM
Warped Rotors glennkill Wheels/Tires/Brakes/Suspension 14 10-05-2007 08:41 PM
You may post new threads
You may post replies
