water pump replacement 6.1 - Dodge Charger Forums
post #1 of 15 Old 06-09-2009, 06:16 PM Thread Starter
modesto83
Senior Member
modesto83's Avatar
(Thread Starter)
Hey guys,
Is there a write up on how to replace the water pump? Mine just went out due to the coolant gunk I think. didn't get the coolant gunk till now and I have 62,000 miles on my SRT.
THanks
Charger SRT8 24"x 10"s, lambo doors, k&n cai, magnaflow exhuast, hid headlight & fogs, tinted tails, led interiors, viper 5900 remote start, 22elite leather console,
modesto83 is offline
post #2 of 15 Old 06-09-2009, 06:55 PM
wickedchargerrt
Banned User
wickedchargerrt's Avatar
Its too simple to write up.
remove the lower cover, drain the cooling system, remove the belt, remove the upper radiator hose, remove the upper metal hose, remove the bolts, replace, fill system with new coolant and distilled water done
wickedchargerrt is offline
post #3 of 15 Old 06-09-2009, 07:15 PM Thread Starter
modesto83
Senior Member
modesto83's Avatar
(Thread Starter)
how do I remove the belt and where is the water pump? I have no idea what it looks like.
post #4 of 15 Old 06-09-2009, 07:36 PM
JackassJesse
Senior Member
JackassJesse's Avatar
Send a message via AIM to JackassJesse Send a message via MSN to JackassJesse
Quote:
Google it????
2008 SXT with; MOPAR CAI, SRT8 Wheels and Exhaust (Reso Delete), Daytona Honeycomb Grille with Script Emblem, Demolded, Turn Key ESP MOD.TRADED IN FOR A...
2007 Black SRT!!!! with; K&N CAI, Yokohama 255/45/20 all around. It's alittle faster....
Added Predator 4/23/10.... Giggity Dyno 4/30/10 400 RWHP!!!
JackassJesse is offline
post #5 of 15 Old 06-09-2009, 07:40 PM Thread Starter
modesto83
Senior Member
modesto83's Avatar
(Thread Starter)
Is this the waterpump?
I did google it trust me. And couldn't find anything specific to the charger, found plenty on the hemi trucks, thats about it. but thanks for your help
post #6 of 15 Old 06-10-2009, 08:51 AM Thread Starter
modesto83
Senior Member
modesto83's Avatar
(Thread Starter)
HOPE THIS HELPS.W/P REMOVAL.DRAIN COOLANT BEFORE REMOVING
1.Disconnect negative battery cable.2.Drain cooling system (Refer to 07 - Cooling - Standard Procedure) .3.Remove radiator fan assembly (Refer to 07 - Cooling/Engine/FAN, Cooling - Removal) .4.Remove accessory drive belt (Refer to 07 - Cooling/Accessory Drive/BELT, Serpentine - Removal) 5.Remove thermostat (Refer to 07 - Cooling/Engine/THERMOSTAT - Removal)
NOTE: The water pump mounting bolts (2) are different lengths. Note the location of the water pump mounting bolts (2). 6.Remove water pump mounting bolts (2) and remove water pump (1).
RADIATOR FAN REMOVAL
REMOVAL
1.Disconnect negative battery cable.2.Partially drain cooling system (Refer to 07 - Cooling - Standard Procedure) .3.Remove upper radiator hose (3).4.Disconnect cooling fan electrical connector (2).5.Remove cooling fan mounting bolts.6.Remove radiator cooling fan assembly (1) from vehicle.7.Remove fan blade from fan motor.8.Remove fan motor from cooling fan shroud.
BELT REMOAVAL AND ROUTE CHART
5.7L/6.1L
CAUTION: Do not let the tensioner arm snap back to the freearm position, sever damage may occur to the tensioner.
1.Rotate accessory drive belt tensioner (6) counterclockwise until it contacts it's stop. Remove accessory drive belt, then slowly rotate the tensioner into the freearm position.
So the instructions say i have to remove the fan assembly. Seems like you guys said I just had to remove the belt and the pump.
post #7 of 15 Old 10-08-2009, 10:10 AM
srt8fish
Senior Member
Bringing this back from the dead. So is this pretty easy to do? My pump is leaking coolant around the seal. Anything I should look out for before I swap it out this weekend?
Inferno 06 SRT8 - Options I,II,III - AFE Stg II - 180 deg Motorad - 20% Tint - BT Mopar Hood Emblem - BT Red Anodized Catch Can - Side Moldings Removed - Trunk Debadged - SRT8 Side Badges - Slotted Rotors - Posi Quiets - HID's Lows/Fogs 8000K
srt8fish is offline
post #8 of 15 Old 10-08-2009, 10:26 AM
GLHS837
Super Moderator
GLHS837's Avatar
One generic tip for removing and reinstalling items that have varying length bolts is this.
Before starting, get a scrap piece of cardboard, or styrofoam. Use a marker to draw a rough outline of the part, putiting small circles for each bolt, number them if you need to. Then, as you remove each blot, push it into the matching hole in the carboard or foam.
This way, come reassembly, theres no doubt about which bolt goes where.
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #9 of 15 Old 10-08-2009, 06:28 PM Thread Starter
modesto83
Senior Member
modesto83's Avatar
(Thread Starter)
I swapped it out, and yes what GLHS said would help a great deal. What I did is got the new water pump, and everybolt I took off i put it on the new waterpump so I would know where they are to go when installing. I replaced my water pump in about 2 hrs.
post #10 of 15 Old 10-08-2009, 06:58 PM
JackassJesse
Senior Member
Why does your water pump need replacing?!?!?!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
3.5 water pump replacement littlecharger V6 Specific Discussion 15 01-27-2009 12:56 PM
Newbie: Stock water pump mattyd Performance Discussion/Modifications 4 05-02-2008 08:21 AM
Killed my water pump wiesek Charger Problems/Assistance 12 02-02-2007 05:52 PM
Problem with Water Pump jsapienz General Charger Discussion 2 08-29-2006 06:46 PM
Water Pump and Idle Pulley HBHemi Charger Problems/Assistance 8 06-29-2006 06:03 PM
You may post new threads
You may post replies
