Rear Differential leak! - Dodge Charger Forums
post #1 of 13 Old 03-24-2006, 06:53 PM Thread Starter
Crazy_luck
Senior Member
Crazy_luck's Avatar
Send a message via AIM to Crazy_luck Send a message via Yahoo to Crazy_luck
(Thread Starter)
Exclamation Rear Differential leak!
I had my 12K oil change today. Before I handed the service manager the keys, I told him there is a small spot of oiil on the ground under the differential. He had the service tech check it out - the passenger side output shaft has a small leak. As of right now, my leak is not bad enough to cause concern, but they recomended I have it fixed at the next oil change.
The service manage mentioned in the last month they have had 5 mangums, 8 300's and 3 chargers with the EXACT same problem (same side and everthing). I would recomend everyone have theirs checked just to be safe.
Crazy_luck is offline
post #2 of 13 Old 03-24-2006, 08:02 PM
dmrowe
Senior Member
dmrowe's Avatar
Send a message via AIM to dmrowe
Re: Rear Differential leak!
Thanks, mine goes in for 6K service next week and I will have them check it.
Charger R/T, Inferno Red, Loaded w/Everything Build Date 10/05
Mods: K&N Air Charger,MagnaFlow Cat Back Exhaust, JBA Headers - Silver Ceramic, Flashpaq 91 Octane Tune, Jet PowrFlo Spacer,180 Degree T-Stat, GSM ESP/TQ Mgmt/Fan Modification, Hood Struts, Honeycomb Grill Insert, 20% Window Tint, KW v2's & Hotchkis Sways, Quaife ATB Differential, Lighted Entry Guards, Ultimate Pedals
dmrowe is offline
post #3 of 13 Old 03-24-2006, 09:22 PM
#430 Daytona
Senior Member
#430 Daytona's Avatar
I had the same problem a few weeks ago. I brought it in to the dealership and they said the rear was over filled with fluid and it caused the gasket to leak on the bottom of the differential. I wasn't buying this but as long as it was fixed I didn't care what they said caused it. I've never heard of that happening before on any car. But they changed the fluid and gasket, I've checked it a few times since it's been fixed and so far everything has been fine.
#430 Daytona is offline
post #4 of 13 Old 03-25-2006, 12:42 AM
mynewcharger
Member
mynewcharger's Avatar
SAME THING HAPPENED TO ME...they fixed it for free...
mynewcharger is offline
post #5 of 13 Old 03-25-2006, 07:05 AM
HemiChemi
Senior Member
HemiChemi's Avatar
Looked at mine when it was in for the first oil change about 2 weeks ago, and it was not leaking. Knock wood...
Inferno R/T+R&T, EVIC; 6-disk CD; Sirius; UConnect; Protect Gp; front and rear spoilers, Daytona grille and insert, R/T emblem and hidden trailer hitch.
There are 10 possibilities:
you either understand binary, or you don't.
HemiChemi is offline
post #6 of 13 Old 03-25-2006, 09:31 AM
elcobra44
Senior Member
elcobra44's Avatar
I had a bad dream about this last night.. Thanks alot.
elcobra44 is offline
post #7 of 13 Old 04-06-2006, 09:37 AM
mejia11
Senior Member
I was changin mufflers yesterday and I noticed the same thing taking to dealership today.
06 Inferno Red (Hemi)
Mods: Tint( LIMO) Super 40's flowmasters, no reso's
4" ChromeTips Diablo AFE STAGE 2 180 T-Stat, Staggered 20" Viper Reproductions (gloss black) 255/45/20 (front) 285/40/20 (rear)
mejia11 is offline
post #8 of 13 Old 04-09-2006, 11:44 AM
Michigan01
Senior Member
5200 Miles, and I get a spot on the garage floor. It's a very lightly colored, thick oil leaking from the differential. Did the dealer offer any explanation, other then the diff being overfilled? Build date 8/05.
Michigan01 is offline
post #9 of 13 Old 04-09-2006, 12:09 PM
ZMagnum
Senior Member
ZMagnum's Avatar
Mine dripped a few times after I got back from a long trip. I had the dealership check it. No leaks. At this point I assume it's from a slight overfill at the factory. Excess comes out the top vent.
Since I have an 8/80 powertrain warranty (all internally lubricated parts) this should be covered for some time to come. My 3/36 is still in place for now anyway.
Others have reported pinion leaks as well.
'08 Stone White Dodge Magnum R/T
MySpace Page -
TheAutoLog Page -
ZMagnum is offline
post #10 of 13 Old 04-15-2006, 11:05 PM
bshopsinger
Member
bshopsinger's Avatar
Check out one of my posts in here regarding this issue. May be on one of the last pages of problems section
bshopsinger is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
rear differntial leak mejia11 Charger Problems/Assistance 3 06-22-2006 07:36 PM
Quaife LSD Differential GSM Charger SRT-8 Discussion 88 04-18-2006 10:04 PM
Differential Issue mejia11 Performance Discussion/Modifications 1 04-08-2006 11:47 AM
Rear Differential Problems? 1HotHEMI Charger Problems/Assistance 5 02-17-2006 12:59 PM
Limited Slip Differential MCaesar Charger SRT-8 Discussion 4 09-28-2005 02:49 PM
You may post new threads
You may post replies
