Car key replacement - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Regional Forums > New England Area
  #1
Old 05-16-2009, 01:08 PM
SublimeInMA's Avatar
SublimeInMA SublimeInMA is offline
Senior Member
Lifetime Supporting Member
Car key replacement
Unfortunately one of my car keys went through the wash. Although it needed the cleaning, it is no longer fully functional. Oddly enough, the locking button still functions but unlock does not.
Anyone know a place for replacement keys other than a dealer? or is this the only way to go with programming issues?
input / guidance appreciated
Tom
__________________
NEMC EXECUTIVE BOARD & ONE OF THE FOUNDING FATHERS
NEMC Events to Come:
MODS COMPLETE: AIRAID CAI W/CUSTOM GRAPHICS ON TUBE/BRYLCREME'D/HOOD STRUTS/BILLET TECH EMBLEMS & SHIFTER/CUSTOM SHIRTS FOR CAR SHOWS BY JINA'S EMBROIDERY/22ELITE CONSOLE W/JINA'S EMBROIDERY/REAR FASCIA "GREEN MONSTER" DECAL // FALKEN F452 TIRES ON HELO HE834B RIMS
Member of CF Photoshop/Artist Group!
MCWL AND PROUD OF IT COOKIES AND CHEESY PUFFS NOW REQUIRED AT ALL NEMC M&G'S
  #2
Old 05-16-2009, 02:33 PM
plumcrazy777's Avatar
plumcrazy777 plumcrazy777 is offline
Senior Member
I believe you can order a key online, like from ebay, have it cut and there is a way to program it to your car with the other key, If you need the program procedure let me know and I will try to dig it up
__________________
07 Plum Crazy Daytona Charger #320 of 1400
04 Dodge Ram Rumble Bee #2331
05 Ram SRT 10 QC Black
Eli
  #3
Old 05-16-2009, 02:41 PM
Scott's Avatar
Scott Scott is offline
Senior Member
I would try to take it apart and let it dry out first.
__________________
07 R/T, Spoiler, Daytona Insert, Glove box light, Mopar Fender CAI, Hood struts, Cabin Air Filter
  #4
Old 05-16-2009, 04:23 PM
dodgetimes2's Avatar
dodgetimes2 dodgetimes2 is offline
Senior Member
Quote:
They DIY key programming only works if you have two functional keys already. I got burned by this one, ended up having to buy from dealer and having them program it via StarScan.
__________________
2006 Go Man Go Daytona #2441 - 20" American Racing Torq Thurst Wheels, AFE Stage 2 CAI, SLP Loudmouth 1 exhaust, Diablo Predator, DIY trunk lid liner, 22elite console cover with embroidery by Jina, visor desguisers by streamlinedesign, glovebox light mod, hood prop mod
1999 Dodge Ram 1500 QuadCab 4x4, 6" Skyjacker suspension lift, 3" PA body lift, 38" SuperSwamper SSR tires, 16"x10" Helo Maxx 6 wheels, nerf bars
2007 Dodge Ram 1500 QuadCab 4x4, stock for now other than nerf bars
  #5
Old 05-16-2009, 05:20 PM
mnunes's Avatar
mnunes mnunes is offline
Senior Member
My Charger: 2006 RT w/ R&T
If the key still starts the car you can use it and another working key to program an additional key. The OP only indicated that the remote control button isn't working.
I agree about letting it dry out really well first.
__________________
How do I.... EVERYTHING!
  #6
Old 05-17-2009, 08:03 AM
Senior Member
Everything works EXCEPT for the unlock.
Unlock was getting troublesome before the "cleaning" and I should have tried to replace it but couldnt.
Is here a link for the new key reprogramming steps someone can put up? I will now be searching for a new key.
Thanks for the help
Tom
__________________
  #7
Old 05-17-2009, 01:45 PM
Senior Member
well this is what I found....on dodgetalk.com
If you have an active fob you can program it like this...
*quoted from the 2001 SLT Owners Manual*
Programming Additional Transmitters
Vehicles will be shipped from the assembly plants with two key fob transmitters programmed only for that vehicle. A total of four fobs can be programmed for your vehicle. Additional fobs can be programmed to your vehicle through the use of a currently programmed fob.
NOTE: When entering program mode useing that fob, all other programmed fobs will be erased and you will have to reprogram them for your vehicle.
Use the following procedure to program additional key fobs.
1. Enter your vehicle and close all doors.
2. Fasten your seat belt(Fastening the seatbelt will cancel any chiming that may confuse you during this programming procedure).
3. Place the key into the ignition
4. Turn the ignition to the ON position (Do not start the engine)
5. Press and hold the UNLOCK button on the key fob.
6. After holding the UNLOCK button for four seconds, also press the PANIC button within 6 seconds.
7. Release both buttons and a single chim will be heard. The chime is an indication that you have successfully entered program mode. All fobs that are to be programmed must be done so within 30 seconds of when the chime is heard.
8 Using the fob to be programmed, press and release both the LOCK and UNLOCK buttons, simultaneously.
9. A single chime will be heard.
10. Within four seconds of hearing the chime, press and release either the LOCK or UNLOCK button on the fob.
11. Repeat steps 8 threw 10 to program up to two additional fobs.
12. Your vehicle will remain in program mode for up to 30 seconds from when the original chime was heard. After 30 seconds, all programmed fobs function normally.
NOTE: If you do not have a programmed transmitter contact your dealership for details.
This info was pulled off of page 18 from my owners manual. Also the dealership charges 100 dollers for a FOB, and 40 dollers to program them.
__________________
Eli
  #8
Old 05-23-2009, 08:16 PM
TBird100636's Avatar
TBird100636 TBird100636 is offline
Senior Member
My Charger: 2011 Charger R/T Plus AWD
Thumbs down
That's a procedure for programming seperate RKE fobs, does not apply to these cars.
__________________
2011 Dodge Charger R/T Plus AWD- Redline-5.7L Hemi Registry #1650 Tbird100636
2006 Dodge Charger R/T- Inferno Red- Gone-5.7L Hemi Registry # 00696 Tbird100636
Last edited by GLHS837; 08-25-2009 at 04:35 AM. Reason: Sorry, but this procedure is ONLY for Sentry keys, not the fobs, themselves, so I removed it to stop anyone from doing this.
  #9
Old 08-24-2009, 08:42 PM
brinagirlk's Avatar
brinagirlk brinagirlk is offline
Junior Member
This wont work on the 08 because you cant push the panic button while in ignition.
__________________
08 DODGE CHARGER - Bought it 6/09, Dual exhaust, air raid intake, Jet stage 2 chip, Tinted windows, alpine s10 sub, rockford 3001 amp,
  #10
Old 08-24-2009, 08:47 PM
SUBNUBS's Avatar
SUBNUBS SUBNUBS is offline
Senior Member
Tom, I replaced my OEM key fobs with a replacement transponder key after adding a remote start system. I don't know if this would help but it's an option: http://www.chargerforums.com/forums/...d.php?t=109510 I'll show the "key" when we're at Mark's on the 14th (and bring some sub nubs, too!).
__________________
Tom
Mods: Yokohama TRZs, McGards, De-Molded/De-Badged, CompuSTAR Remote Start, Bob's 6db GPSSR, SRT Spoiler, Honeycomb Inserts, Danko Chin, BT Shifter Plate, OE Fogs and Hood Struts, Cabin Air-Filter, CCD back-up camera w/ trunk lock mod, Sylvania Silverstars.
Tunes: Kenwood DNX6140 & Amps, Polk MM691s, BA G310-4 Subs & Zenclosure Box, mini-B for wifi downloading.
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Replacement Key Maxell Charger Problems/Assistance 41 01-21-2013 02:32 PM
HELP!! turn key all the way and car won't start damiendvl99 General Charger Discussion 12 10-03-2008 08:07 AM
lost key - is there any way to find a replacement key without going to the dealer? sheek's Silver bullet Charger Problems/Assistance 20 07-12-2008 03:29 PM
2008 car smart key?? hawk25 Interior Discussion/Modifications 8 02-22-2008 09:21 PM
How Do I Get A Replacement Key For Stock Wheel Locks on an SRT-8? WKuze13 Wheels/Tires/Brakes/Suspension 5 01-28-2008 01:43 PM
© AutoGuide
