07 Shift Knob removal/ BT shift plate install - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Interior Discussion/Modifications
  #1
Old 04-11-2009, 12:02 AM
desertcharger's Avatar
desertcharger desertcharger is offline
Senior Member
Supporting Member
I went looking through the site to find info on how to remove my shift knob- and found lots of different info- so if figured I would document my install for an 07 Charger and hope it helps someone else out.
Before
On mine- there was a little knotch in the front of the chrome ring- there is no set screw inside it
To remove the shift knob, insert a screwdriver inbetween the silver cap and the knob itself and twist the screwdriver
the silver piece will pop off and fall down
Then just pull up on the knob itself- it will pop off
Now use a small screwdriver on the side of the chrome bezel surrounding the shifter plate- it has four tabs witm multiple teeth on it- keep moving around the bezel prying and lifting until it comes off
Clean the plate with some mild cleaner- then peel the strips off the New overlay and apply carefully- line up the track for the shifter evenly
Push the Chrome Bezel back on- it will sit a little higher now
Put the chrome shift knob piece back on
Put the shift knob on (do not put it backwards like I did in the pics)
Enjoy (after you turn it around so it is facing the correct way)
__________________
2008 SRT8 Charger Intune 91octCAI and AFE so far
R.I.P Supercharged 2007 Charger R/T R&T
  #2
Old 04-11-2009, 12:09 AM
HUNtastic's Avatar
HUNtastic HUNtastic is offline
Senior Member
Send a message via AIM to HUNtastic
thanks for the post!!!!
i always felt that little cutout on the bottom of the knob. i thought about cutting the shifter an inch shorter.
__________________
FOR SALE !!!!
http://www.chargerforums.com/forums/...d.php?t=137588
[CENTER]All Silver Chargers! Check this out!!! http://www.chargerforums.com/forums/...php?groupid=19
  #3
Old 04-11-2009, 05:27 AM
MR-SMITH's Avatar
MR-SMITH MR-SMITH is offline
Senior Member
Cool. My shaft is threaded. I think thats 06's and early build 07's
__________________
SUPER BEE 936/1000
  #4
Old 04-11-2009, 06:59 AM
Phanta5m's Avatar
Phanta5m Phanta5m is offline
Senior Member
Lifetime Supporting Member
Quote:
yes, mid 2007 (mar) is the change you see above
__________________
Quote:
Originally Posted by Gladiator View Post
I call it the rainbow roller.
  #5
Old 04-11-2009, 10:32 AM
Senior Member
Supporting Member
Quote:
yep- mine was delivered to the dealer mid April and purchased by me April 30th...
coming up on her second birthday
__________________
  #6
Old 04-13-2009, 01:36 PM
xious's Avatar
xious xious is offline
Member
Wow, that shifter plate looks smooth. I really like that. I may have to get one of those.
X
  #7
Old 04-13-2009, 02:07 PM
My06ChargerRT's Avatar
My06ChargerRT My06ChargerRT is offline
Senior Member
Here is mine!
__________________
P.J.
2006 Silver R/T
  #8
Old 04-13-2009, 05:18 PM
Senior Member
Supporting Member
Quote:
I really like the change it made in the interior- I'm actually really surprised- I never thought I would get one but couldn't resist when I saw it in person
Quote:
Originally Posted by My06ChargerRT View Post
Here is mine!
Sweet
__________________
  #9
Old 11-11-2009, 05:02 PM
***Q2***'s Avatar
***Q2*** ***Q2*** is offline
Senior Member
Thank God For This Write-Up!!!
__________________
2013 Pitch Black Dodge Charger R/T Plus
  #10
Old 11-11-2009, 07:25 PM
Senior Member
Supporting Member
Glad it helped!! Lets see your pics!
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
OEM parts F/S: Shift knob, shift bezel, center console cover toxico Parts For Sale/Wanted 6 11-02-2007 08:34 PM
Shift knob removal binster Interior Discussion/Modifications 6 09-14-2007 06:12 PM
Shift knob removal Summo Interior Discussion/Modifications 7 06-28-2007 08:54 AM
Stupid question on shift knob removal... jeadler Interior Discussion/Modifications 1 03-23-2006 01:36 PM
© AutoGuide
