My engine light and oil light have been coming on the last few days. (Have not pulled h codes yet) and my oil pressure is real low - 4 to 5 PSI at idle after the car is running for a few minutes.
I just had plugs changes for he 30 k service. I also switched form Royal Purple (K&N filter) to Amsoil (Amsoil filter) 5w20 Synthetic when I got the plugs changed out.
The stick actually reads more than full. Could this be the cause?
Thx!
D a n a
__________________
Genius is one percent inspiration and ninety-nine percent perspiration!
How much past the full mark is it? A quarts worth? Do you check it after you let it idle for 5 minutes? I'm no mechanic, but I'd venture to guess that if it's WAY overfilled, it can cause problems. I underfill mine if anything.
__________________
2007 R/T | Diablo 93CAI | AFE Stage II CAI | Flowmaster Super 44 Catback | SLP Udrive Pulley | BT Catch Can
Blacked out 20x9 SRT wheels | Toaster Mod | Clock Tower Mod
Best pre pulley 1/4: 13.64 @ 101.33 mph
If you don't like what I'm saying, my response can be re-calibrated. Turn the ignition key to the ON position. Re-read my post and at the same time turn the key to the ACC position. My response has now been re-calibrated.
What made you switch from RP to Amsoil just out of curiousity?
Xian
__________________ 2006 Dodge Charger R/T Daytona Edition 1773 of 4000 Mods:
Front Blinker Mod, Elite22 Console cover, Side Body Molding delete, BWoody Sway Bar End Links, Mopar CAI Beater Car: 2003 Ford Crown Victoria LX
Bone Stock!!
I don't see how a too-full dipstick reading would result in low oil pressure.
Have you been driving the car in this condition? If so, you're asking for WAY bigger problems if there is in fact a real problem. Is your engine noisier than usual when this happens?
Seriously, I would have had the car flatbed'ed to a dealer in order to determine whether it was a simple case of failure of the oil pressure sender or if you really do have super low oil pressure for some other reason. And if you do have a real problem with oil pressure, chances are if you drove the car in this condition you've already messed something else up big time.
__________________
/Steve
1987 Pontiac Trans Am GTA
1998 Pontiac Trans Am WS6
1978 Pontiac Trans Am
1978 Pontiac Trans Am 4-speed SE
2006 Daytona R/T Tor-Red (59 of 200 - Canadian)
Oil light just came on yesterday. Idle is fine when I am driving the car. It is a very low Idle when stopping, goes down to like 2 to 3 psi and then the oil light comes on. I have not been driving it very much before the light came on or after.
I just picked it up from the dealership last Wednesday. It is in no way damaged, the engine sounds healthy and strong, no loss of power, just the light and the low idle when coming to a stop.
D a n a
__________________
The economy. I am an Amsoil distributor but instead of getting Amsoil synthetic for 4.25 a quart, I have been paying 6.99 or 7.99 for RP eginning wiht my first oil change 3 years ago. I figured I would eat my own dog food, and go wiht the Amsoil, that's all. She does seem to run a little cooler with Amsoil but I have not driven her very much or very far since the switch. You cannot go wrong with either oil. Both products are the best of the best along with M1
D a n a
Quote:
Originally Posted by xtcbct
Dana,
Xian
__________________
__________________
- Former owner of a 2007 Charger R/T AWD -
Rest In Peace Mom (1947-2010) ... I will love you forever ... I miss you ... '13 Mustang GT 6-spd man, Sterling Gray, Recaro seats, Track Pack.
- ordered 6.6.12, born 7.25.12, mine 8.11.12 - '10 Focus SE sedan, auto, Sangria Red
the tsb says the update is for the 07 - 08 LXs. Mine is an 06. I wonder if that put's me out of the running to receive it.
D a n a
Well, TSB's are not recalls .... you will most likely only have that done at no charge if your car is still under the original 3/36 warranty ...
__________________
