» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Exterior Discussion/Modifications
Please Visit our Site Sponsors
ChargerForums.com is the largest Dodge Charger Forum on the internet. Registered Users do not see the above ads.
Thread Tools Display Modes
  #1
Old 03-28-2009, 03:45 PM
MrDolomite's Avatar
MrDolomite MrDolomite is offline
Senior Member
Post Old School Charger Script Emblems
Edit: See Plum Crazy for Old School Charger Script Grille Emblem for install pics
Top: Chrysler OEM p/n P2841886, Charger script grille emblem with mounting pins for 1966–74 Charger, Size 8 Inch X 1.5 Inch
Bottom: Chrysler OEM p/n P3504807, Charger script fender emblem with adhesive for the 1971-74 Charger, Size 6.5 Inch X 1 Inch
You can pick up both badges at your dealer.
This is not some flimsy plastic part, they are metal. The pin one weighs almost 3oz and the sticky one is nearly 2oz. The pins are permanently part of the badge, but I supposed you could cut them off. But, since the back is not flat, it would be tricky to add adhesive. I'm planning on putting them on the grille and trunk, respectively.
For size comparision, here they are next to the original trunk badging.
__________________
MrDolomite - PLMCRZ8 (forum pics) (flickr pics) (cardomain) (fuelly)
Mods: Zoomers, Grille Lighting & Hood Scoop, Turn Signal, Front & Rear Blinker, O-rings, Pull Off Shift Knob, Underhood Dress Up, Demolded & Debadged, 6.1 HEMI badge, Thermalnator Intake Gasket, Billet Tech Underhood in new darker purple
To Do: Interior Lights, Trunk Liner, Exterior Vinyl
Last edited by MrDolomite; 08-31-2009 at 12:53 PM.. Reason: add link to "Plum Crazy for Old School Charger Script Grille Emblem"
  #2
Old 03-28-2009, 05:11 PM
Elmo Elmo is offline
Member
How would you get the emblem with the pins to hold to the grille?
__________________
'06 Brilliant Black Charger R/T
Mopar CAI | Predator w/ 91 CAI tune | RamAir Hood | Zoomers | 180 T-Stat | BT Catch Can
  #3
Old 03-28-2009, 05:29 PM
MrDolomite's Avatar
Senior Member
Quote:
I'm still working on that. Originally I was going to use flat type speed nuts, but in order to get them with a small enough thread size to fit onto the pins, the wings aren't large enough to span the holes of the honeycomb grille. And looking at the SRT badge was no help, because that one has molded plastic clips instead of pins and nuts.
  #4
Old 03-28-2009, 05:33 PM
a14umbra's Avatar
a14umbra a14umbra is offline
Super Moderator
Lifetime Supporting Member
Another option.
__________________
*Hood Emblem by BilletTechnology
Vote for Morgan
"Those who have long enjoyed such privileges as we enjoy, forget in time that men have died to win them."
- Franklin D. Roosevelt
Thank you to those serving or have served.
Gunsmoke called, they want their wheels back.
- Gladiator
  #5
Old 03-28-2009, 05:42 PM
MrDolomite's Avatar
Senior Member
Question
Quote:
Originally Posted by a14umbra View Post
Another option.
That's sharp, I like having the Dodge name on the car somewhere. I've seen that in YearOne's catalog as VC145, 1971 trunk lid with adhesive.
Q1: Is that one the you have?
Q2: How did you attach it to the grille through the honeycomb? (see my speed nut dilemma above)
Q3: What is the widths of the script part and then the overall? In looking at the adhesive one I have for the trunk, I think it may look too short.
__________________
  #6
Old 03-28-2009, 05:43 PM
RAINMANyeh's Avatar
RAINMANyeh RAINMANyeh is offline
Senior Member
I went buy a local auto parts store and purchased a pack of roll pins, a pack of speed nuts, and a pack of JB Weld.
1) Pick the appropriate size roll pin to slide over each post. The fit will be tight and you may have to gently tap the roll pin down onto the post with a hammer. Be careful as not to break the post.
2) Use a dab of JB Weld along the split in the roll pin to fully secure it to the post. Allow it to dry and set.
3) Slip the extended posts (roll pins) through your grill and use the speed nuts to hold the Charger Script in place by screwing onto the roll pins. You can use another dab of JB Weld on the back of the speed nuts to secure everything and make sure noone rips your Charger Script off your baby.
It's not that hard to do, just a little time consuming. I hope this helped... Post pics when you're done.
__________________
2007 TorRed R/T R&T
Get in, sit down, shut up and hold on!!!
  #7
Old 03-28-2009, 06:44 PM
a14umbra's Avatar
Super Moderator
I'm not sure. I got it from someone on ebay.
I used a piece of cheesestrap to make a bracket that goes through the grill and bends over to hold it on. I then used Gorilla Glue to glue it to the bracket.
I'll have to measure it tomorrow. The script part is smaller than the one that is script alone.
More pics
http://www.chargerforums.com/forums/...ad.php?t=39811
__________________
Vote for Morgan
- Gladiator
  #8
Old 03-28-2009, 10:08 PM
bwhite220's Avatar
bwhite220 bwhite220 is offline
Senior Member
I cannot wait to do all charger script badges on the inside and outside. It just looks classy...
Thread Tools
You may not post new threads
You may not post replies
Similar Threads
Where can I get those script charger emblems? goval Exterior Discussion/Modifications 8 08-30-2008 02:37 AM
Script Charger Emblems Kray561 Parts For Sale/Wanted 6 07-06-2008 07:00 AM
Where can I find small Old school charger script emblems? Sublimeon22s Exterior Discussion/Modifications 4 05-31-2008 07:32 AM
Where to get charger script emblems? Sublimeon22s Exterior Discussion/Modifications 12 05-07-2007 09:21 AM
Script Charger Emblems Calicat771 Exterior Discussion/Modifications 14 12-04-2006 09:39 AM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin®. Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© AutoGuide
