Rear axle seal leak already ? 45k.... - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
  #1
Old 02-20-2009, 03:57 PM
Jason84 Jason84 is offline
Senior Member
Send a message via AIM to Jason84
Well got my oil changed today. They said my pass side rear axle seal has a slight leak already... Car only has 45k Miles on guess its due for maint but they said it would be $300 to get fixed?
Now Ive worked on my old cars a lot... axle seal is what a $5-$10 part?
Probably 30 mins to pop it out and refill the rear end? Or are these that complicated???
  #2
Old 02-20-2009, 04:00 PM
Crazy_luck's Avatar
Crazy_luck Crazy_luck is offline
Senior Member
Send a message via AIM to Crazy_luck Send a message via Yahoo to Crazy_luck
Have them double check the fluid is not coming out of the differential vent. If it is/was, there would be evidence of it puddiling above the passenger side seal, where the seal wouldn't be leaking from.
  #3
Old 02-20-2009, 04:07 PM
wickedchargerrt's Avatar
wickedchargerrt wickedchargerrt is offline
Banned User
Its common. The guy in the stall next to me has one rack for warranty axle seal and pinion seals that he pretty much does 8 hours a day. i've seen em on vehicles as low as 10k and on average every 30k. Worse on 4wd/awd vehicles with 8 axle seals and 2 pinions
  #4
Old 02-20-2009, 04:09 PM
torred1771's Avatar
torred1771 torred1771 is offline
Senior Member
Send a message via AIM to torred1771 Send a message via Yahoo to torred1771
ive already replaced my rear axle seal at 41k miles and im at 42500 miles and its leaking again, this time we think its from the vent.
__________________
For Sale:
2006 Dodge Charger Daytona RT
$20,000 O.B.O.
PM for details!!!!
  #5
Old 02-20-2009, 04:15 PM
Banned User
make sure the vent is clear and free of obstructions but seapage from the vent tube is fine
  #6
Old 02-20-2009, 04:36 PM
SRT8Tech's Avatar
SRT8Tech SRT8Tech is offline
Senior Member
One word, VENT!!!
__________________
SOLD my Procharged 2007 SRT8 Charger.
New addition #1) Billet black stripe 392 Challenger
Bone stock for now.
Best run so far, 12.25 @ 113 on a PLUS 1200 DA.
New addition #2) #419 Mopar '10 Challenger.
Bone stock and staying that way.
Best run so far, 13.20 @ 105.8 on a PLUS 300 DA
  #7
Old 02-20-2009, 04:40 PM
torred1771's Avatar
Senior Member
Quote:
Originally Posted by SRT8Tech View Post
One word, VENT!!!
so whats the fix?
__________________
For Sale:
$20,000 O.B.O.
PM for details!!!!
  #8
Old 02-20-2009, 04:49 PM
Banned User
there is no fix. Its a vent
  #9
Old 02-20-2009, 05:34 PM
Crazy_luck's Avatar
Senior Member
Quote:
I had an issue with the fluid coming out of my vent as I drove because it was foaming up. My dealer looked into it and found a TSB for a Jeep that had this problem - they used the TSB part from the Jeep to fix it on my Charger. It consists of a tube shaped filter with the vent on the end - it allows the foaming fluid to expand into it, then drain back in when things stop moving and the heat dissipates.
  #10
Old 02-20-2009, 05:46 PM
chargerboy04 chargerboy04 is offline
Senior Member
Send a message via AIM to chargerboy04
i have the same exact problem and the same mileage..dealership said its a 600 dollar job =( or they said every oil change i can just make sure the fluid is full and keep it up and i'll be ok
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
Axle Leak PaCharger Charger Problems/Assistance 11 11-08-2008 10:06 AM
O-Ring seal tranny leak vrykeen Charger Problems/Assistance 9 12-26-2007 06:19 PM
Rear main seal becnstv Charger Problems/Assistance 3 07-30-2007 07:22 AM
Rear seal leaking at 27K Rivalry Charger Problems/Assistance 1 05-03-2007 11:45 PM
Rear axle seal leaking. bskylerj Charger Problems/Assistance 11 03-14-2007 10:29 PM
© AutoGuide
