NOTE: I wanted to thank user "tanbam" for these instructions, and for his permission to use them to start this thread!
This map updating process is for the CTP11 & CTP12 radios which are on the 2011 – 2012 Charger, and has a magnifying glass icon for the "Where To":
If you have a 2013 – 2014 Charger, the files needed are different and instructions can be found here:
HOW TO: Map Update on Uconnect CTP13+ (2013 - 2014)
Getting Started - What you will need:
(1) Compatible Garmin Nuvi which has 3D maps and junction views.
(2) Compatible USB flash drive at least 8GB in size
Step 1: Getting update files from the Nuvi
Begin by plugging your Nuvi into the computer and running GARMIN Express. The program will let you update your Nuvi software and will install the latest map update. This will take some time, so just let it do its thing.
After the Nuvi has been updated and has the latest maps, you must enable the Mass Storage feature so that you can browse the files using your computer's file explorer. After this is done, your Nuvi will show up in your computer like a normal USB flash drive. This only needs to be done once.
To enable Mass Storage in the Nuvi:
1) Disconnect the Nuvi from the computer.
2) From the main, "Where To?" screen, tap the "Volume" button.
3) Tap and hold the upper-right corner for about 10 seconds to enter the Diagnostics Page.
4) Scroll down and tap "MTP Settings".
5) Select "Mass Storage" and tap the "Save" button.
5) Tap the back arrow button twice to go back to the main screen.
After Mass Storage is enabled, plug the Nuvi back into the computer. To copy the update files to a USB stick:
1) Ensure that the computer is set to "Show hidden files, folders, and drives", and that "Hide extensions for known file types" & "Hide protected operating system files" are both unchecked. This will allow you to easily find the Nuvi files and avoid confusion.
2) Plug a blank USB stick into your computer and create a folder named "Garmin". All of the update files will go into this folder, regardless of where they came from in the Nuvi. Inside the Garmin folder, create two more folders named "ASR" and "JCV".
3) Open the Nuvi 'drive' and browse to the ".System" folder which should be visible at the top of the list. If you don't see it, go back and double-check that step 1) was completed properly.
4) Copy ONLY the following three files from the ".System" folder in the Nuvi into the "Garmin" folder in the USB stick:
gmapprom.img (03/17/2021)
gmaptz.img (03/08/2021)
gmapbmap.img (03/14/2011)
5) Browse to the ".System\ASR" folder in the Nuvi and copy ONLY the following four files into the "Garmin\ASR" folder on the USB stick:
06PGQW3K.SRX (03/17/2021)
06PGQW3L.ASR (03/17/2021)
06PGQW3M.ASR (03/17/2021)
06PGQW3N.ASR (03/17/2021)
*Note that these file names are ONLY for 2022.10 map.
6) Browse to the ".System\JCV" folder in the Nuvi and copy ONLY the following file into the "Garmin\JCV" folder on the USB stick:
D3191370A.JCV (03/17/2021)
Large JCV File D3060350A.JCV (851.028 MB)
*Note that this file name is ONLY for the 2022.10 map
**Note that there are three different versions of the JCV file, determined by size! The above listed is the MEDIUM sized one!
When you are finished, the folder/file structure on the USB stick should look like this:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 06OT61A8.SRX
. │ 06OT61A9.ASR
. │ 06OT61AA.ASR
. │ 06OT61AB.ASR
. ├───JCV
. │ D3191340A.JCV
Some folks may notice that this does not include the full set of update files that come with a Nuvi update, however, these are the only files that are required for the CTP11/12 system. The other files will just be taking up unnecessary space.
Step 2: Generating your unlock code
There are two programs that you will need to generate the unlock code for your map/car combination. You will need to generate a new code for each new map.
The first program is called GMapTool, and it is used to identify the FID number for each new map.
GMapTool can be downloaded from here:
GMapTool
To use this program, install it to your computer. After it is installed, open it and you will be presented with a window.
1) Drag-and-drop gmapprom.img from the USB stick into the blank area under "File Name"
2) Click the "Info" button.
3) Record the FID number.
After you have the FID number, you need to get the 10-digit Device (UNIT) ID number from your radio. You can either find it in the settings menus, or you can wait until the radio prompts you during the install process. It's easier to get it beforehand, though. It will be on a screen that looks similar to this:
Now that you have your Device ID number from your car and the FID number for the map, it's time to generate your 25-digit unlock code. To do this, you need Jetmouse for PC available here:
Jetmouse for PC
After you get the program, open it on your computer.
1) Enter your 10-digit Device (UNIT) ID code in the "Enter your Unit ID here:" box.
2) In the "Select Map Product:" section, scroll to the bottom and choose "<custom mapset>'
3) In the new window, enter the four-digit FID number in the "FID (or MapID):" box and click "OK".
4) Click the "Generate" button in the bottom left corner.
5) Copy the map unlock code (or take a picture of it!)
Step 3: Updating the maps in the car
The update package is ready to go into the car. I don't have access to a CTP11/CTP12 right now, so I'm going to try to go from memory...
1) Toggle the Start button to the ACC or RUN positions. The car engine needs not be running, but be aware that the car will turn itself off in the ACC or RUN positions after a period of time. It is critical that you don't allow the car to turn off after the update process begins. Either babysit it by periodically cycling the Start button to reset the timer (make sure the doors are closed when doing this) or just go for a drive while the map is being updated. The update can take more than an hour, so plan accordingly.
2) Go to the navigation screen and plug the update USB stick into the USB jack in the center console. The radio will recognize that an update disk has been inserted, and will begin validating the files on the USB stick. This may take some time.
When the validation process passes, a window will pop up and will ask you if you want to update to the newer map. Proceed through the onscreen prompts, including entering in the 25-digit unlock code that you generated earlier.
3) After this, the radio will reboot and begin copying the new files into the system. This will take a long time, so just let it finish.
Occasionally, the radio may lock up at the reboot stage. If it doesn't reboot after a minute or so, you must pull the radio fuse in the trunk. I have no idea why this happens, but nothing bad happens to the radio and you can simply repeat from step 1 again after plugging the fuse back in.
4) After the install process has reached 100%, the radio will again reboot. It may either tell you that the map update was successful or not, but if it got all the way to the end, the update was successful regardless of what it says.
5) Go into your settings and verify that the maps were updated to the latest version.
6) Enjoy!
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 06OT61A8.SRX
. │ 06OT61A9.ASR
. │ 06OT61AA.ASR
. │ 06OT61AB.ASR
. ├───JCV
. │ D3191340A.JCV
GMapTool
Jetmouse for PC
6) Enjoy!
