Ok, so my 2006 dodge charger Hemi 5.7 has started to stall again!! I say again because it has stalled for a couple of reasons in the past. It had the gas tank issue - fill up with gas and the car stalled because gasoline was getting sucked into the EVAP system. That was a pain but it was fixed. The second stall episode was due to the ECM - that one was scary. The car would cut out at anytime - a few times going 70 MPH on the highway in heavy traffic. I had the ECM replaced and that fixed THAT issue. Now the car is stalling at idle or while slowing down/stopping - typically after sitting overnight or after work (8 hrs). This typically occurs within 5 or so minutes of startup. I have so far replaced - TPS, EGR, ECT sensor and the transmission conductor plate (I had a P0700 code & I thought it was the conductor plate). Likely threw the code because the engine shut off while I was slowing down and caused some generic code off from the TCM. There are no other codes - it's really frustrating and (although I love the car) it has me on edge because I don't know if it's going to stall on me - I live in DFW (dallas/fort worth TX) and traffic is horrible. Please let me know if you have any ideas on what the issue might be. I'm thinking there might be an issue with the EVAP system - no codes. However, upon my hours of research, I read a similar issue with a Chevrolet Trailblazer - guy replaced alot of stuff and his problem ended up being solved by replacing the vapor canister. All insight is appreciated. Thanks!
