nice BUT YOU CANT DRIVE THAT ON THE STREET IN THE REAL WORLD!!! WITH THE AIR FILTERS UNDER THE CAR LIKE THAT IF YOUR CAUGHT IN A RAIN STORM YOU ARE SO FUDGED IT AINT FUNNY. YOU'LL SUCK WATER AND BLOW THE MOTOR ALL TO H3LL AND PLUS THE HEAT FROM THE HOT STREET IN THE SUMMER MUST KILL ALOT OF POWER PLUS THE FILTERS ARE NOT IN A DIRECT AIR STREAM TO FORCE CLEAN COOL AIR INTO THEM AND THE FACT THAT NOT ONLY WITH THEY PICK UP HEAT OFF THE STREET BUT ALSO FROM THE DRIVE TRAN OF THE CAR. NICE WORK BUT POOR LAY OUT FOR THE INCOMING AIR
Yeah, you can drive it and the system is bad@$$. Most come from Squires Turbo Systems. Theyve designed everything for almost every car to be turbo'd like that. Here go yo http://www.ststurbo.com and see.
i was actually at the shop the first time the car started up after being under the knife for months on end.
the job is 100% custom fab from the ground up. custom made twin tube intake to the tb. each coming from an intercooler(2 of them total) on either side of the radiator.
this thing is a beast, if you follow my link above, and look on the lower left hand at "whats new" theres a link to a short vid of the car on the dyno and stuff, shows a dyno chart too.
this car is incredible, getting to see it thru stages of being built is amazing, almost everysingle piece was hand cut/shaped/welded. built and tuned from the ground up in house at Fastlane.
Related Threads
Charger Forums
2.9M posts
104.7K members
Since 2003
