On my 2007 Daytona I recently got, there were a few problems, as one might expect. One of them was that the right side fog light does not work. When I went to replace the bulb, there was no wiring connected to it. Hmmm, there's your problem... I checked the routing for the wire for the left (driver) side, and could see where it came off the main harness and went down to the fog light. On the right side, nothing. High beam, low beam, turn/marker lights, washer fluid, something attached to the radiator (temp sensor?), but not fog light. No gaps in the harness where a wire could have been cut, either.
Could someone help me by explaining or posting a picture of where the right fog light comes off the harness? I can connect it myself with a relay, but I'd rather use the original wiring if I can.
Thanks,
Randy
Thanks,
Randy
