Alright, this is the second time this has happened to me now. I disconnect the battery to work on my car and once I reconnect and start her back up again everything works properly except the auto-up drivers side power window. The auto-down works fine and the passenger side auto-up & down works perfect. Last time the auto-up on the drivers window just started working after a day or two, but this time it hasn't started working again yet.
Has anyone else run into this problem or know a fix for it? Thanks.
I believe if you run the window down and hold the button in the down position for a couple of seconds then do the same on the up position they will start working again..Ive had this happen once and that took care of it.
Just had the auto-up on the passenger window freeze up. Everything else works fine. Did the 'reset' that has been discussed herein and viola, it works perfectly now! Thanks to all.
