Ok so, i locked. My motor right in my 2010 3.5 charger, we swapped it out with another 3.5 , we didn't waste any transmission fluid or anything , but now the car won't go into gear all wires are hooked up properly I really really don't know what's going on with it now? do I need to get the Hal reprogrammed?
What diagnostic trouble codes (DTC) are being posted? Plug a OBD2/CAN scanner into the OBD2 port (under the dash and left of the steering wheel) and see what DTC are being posted.
When you say it won't go into gear
Does it come out of park ? Is it mechanically jammed or stuck in park ?
Or does the shifter works but when you shift into a gear nothing happens the transmission is not engaging ?
Related Threads
Charger Forums
2.9M posts
104.7K members
Since 2003
