I just swapped my O.E. single disc radio for an O.E. 6 disc unit with satellite and rds.
I am curious if there is a way of activating the satellite radio.
Can I just call the provider and give them the serial number for the radio?
Who is the provider? Serius? XM?
It's Sirius. Did you install the satellite antenna as well, or just the radio? You would need to get the number off the radio and call Sirius to activate it.
Your car will not have the Sirius antenna unless it came with it from the factory. The head unit should have a plug on the back were you would plug in the Sat radio antenna. The head unit itself has the sirius tuner built in, but not the antenna. You can buy an aftermarket antenna off Ebay that will work. just put it up under the center grill thing on the dash.
