It's high time I replace Chrysler's stupid air pump solution for flat tires with an actual spare tire and jack setup as has worked since the Conestoga wagon carried spare wheels. Any recommendations for a good jack that will work with a 2016 Charger? I'd like something a little more stable than the 3 dollar jack the OEMs usually supply with their cars. I think I'd prefer to not go with a hydraulic to avoid leaks. Thanks.
Thanks, but not what I'm looking for. I'll probably just get a standard screw jack, but I was hoping someone might have a better solution than the actual factory jack.
Check the height on screw jacks. A stubby one might fit, but I suspect your car is too low for most. A good quality scissor jack with a solid footprint is probably your best bet. Slow, but effective. They also stow easier.
