i need help!! when i put the shifter in drive it wont move but it will drive in reverse. i try putting it in drive and it wont move. then i turn it off and on then it goes in drive and then it moves. it drives good no sounds or gear slips shifter prob? tcm?
same problem, took it to dodge they changed oil and updated the pc, drove fine for about 10 key cycles then started up again and wont drive, took it back said my pcm is fried its probably the problem going to cost 1k to install it so they can further diagnose my car, said nty bought one that is pre-programed and waiting for it to ship in for results, but i think it should be ur pc cause once u turn the car off u soft reboot the pc, if i turn my car off for a week it drives fine for about 30 miles or more then same problem happens again.
Hey Alfredibrahim, just want you to know that you are responding to a post that is 5 1/2 years old. Not sure you saw that. However, it would be good to see if the new pcm you ordered works to fix your issue.
