Hello Charger Folks,
I did a write up on the Predator designed to offer some helpful info to everyone from novice to experienced. When I first got mine, I noted that tips and such were all over the net, DS forum, and this forum. I have tried to cram it all into one article, which I have been editing as needed. The article is generated for a 5.7 motor, but the 6.1 and even 3.5 tool users will still get a great deal out of this article, as most tool features are synonymous.
Also, of great value, is an Excel spreadsheet with every single menu option there is in the tool, which I call a "Menu Map". Start in the upper left, select an item in the column and follow its choices to the right. Note the different sheets available at the bottom of the page.
Special thanks to Mike, John, Christy and Johan at Diablosport who have been very generous with their time as I bugged them about several specifics to make sure the info was accurate.
Instead of copying the article here, I am going to link to it as I keep editing for both accuracy and clarity, and it is four times the size allowed for one post! Please be advised that if you print the document, you should still check back, as I update it frequently as revisions are released to the tool. The Menu Map is updated as well but can be downloaded anytime as well.
Revision II Updates 6-1-08:
* Corrections to reflect tool upgrades throughtout.
* Renumbered sections to reflect sections added.
* Added PIDS required for CMR in section 13.
* Added section 6 Custom Tunes.
* Added section 7 Quick Adjust.
* Added section 15 DS Downloader.
I hope you find it helpful.
THE KNOWLEDGEBASE IS FOUND HERE! --->>> Click Here To Open The Article (Updated 3-1-09)
CLICK LINK FOR MENUMAP FILE IN; Microsoft Excel or in the Adobe PDF format.
