2006 dodge charger 5.7 daytona top banana ? dtc codes abs lights esc light
I've got a 06 charger. And the trouble code I'm currently getting is u0121 u1120 but the car is also in limp mode with the esc bas light on and abs light on. The front left caliper seems to be sticking and is heating the rotor up to well over 5 or 6 times hotter than the rest of the rotors. I thought it was a stuck caliper so I relplaced it with a new one and bleed the brakes with no change to how the caliper was acting and seems to not have got better at all. So I replaced the and sensors still no change .so I removed the abs control module of course leaving the hydraulic unit. Still no change it is still acting locked up. What am I missing about the brake not releasing and why is this car in limp modevseems to have plenty of transmission fluid
