Started the car (2007) MIL came up w/ a rough idle. Restarted, MIL still up but idle improved. Went and put gas in it, as I had about .5gallons left and thinking the light would magically disappear with actual gas in the tank.
Ran Dx code and got some numbers. Anyone know what it means? H719.
Light still up, plan to take it to dealer tommorow but I hate the not knowing wait. :/
Does this link help: http://en.wikipedia.org/wiki/OBD-II_PIDs
As far as I can tell, it should start with P C B or U. So I don't think this is much help. It will be interesting if you post what it turns out to be.
I hope that it's nothing serious!
Andy
do the fuse removal trick to try to turn off the mil
how did you get that code? (sorry dont know what Dx code is )did you do the key thing to check codes? if not you should try that
that code is invalid
i tried this website http://www.iequus.com/support/obd2_definitions.php
Yah, by dx I meant diagnostic (the key thing) and that number is all it listed. I will try the fuse removal trick in the morning.
I broke down and read the manual...
It said something to the effect of, drive it a few times and if it doesnt go away panic. So I went and bought beer, to contain the panic.
