06-early 07 all you have to do is unscrew the shift knob. Late 07-10 you have to pop off or push down the chrome ring then pull up on shift knob. For the screw off type the ring doesnt have to come off, at least I didnt take it off on mine, when I swapped out shift knobs.
OMFG, please please. Just FYI, on the 14 Charger, AFTER you pry down the chromed plastic collar (I used a dull butter knife), if you look at the base of the shift knob, you will see a yellow tab. This is a flat pin that is folded to fit snug in the hole that goes THROUGH the shifter post. NO amount of pulling is going to remove the knob, you will bust a gut first, I know I almost did. Pull out the pin with a pair of needlenose, and then the knob with pop right off with hardly any effort.
I WISH SOMEONE WOULD HAVE MENTIONED THIS BEFORE I ALMOST HURT MYSELF!
Related Threads
Charger Forums
2.9M posts
104.7K members
Since 2003
