#1
May 18, 2016
In my 2011 Dodge Charger Rallye can the area sure the push to start button that says "off, acc, run"? That is damaged and you can't read the words. Thanks in advance.
See less
See more
1
#2
May 18, 2016
Everything is replaceable if you're willing to a. spend the money b. learn how to do the work yourself
#3
May 18, 2016
I looked around for the part can't seem to find it . & I couldn't find a diy video either.
0
#6
May 18, 2016
68207000AD Start button assembly. $52 I think it includes the suround
#7
May 18, 2016
(Edited)
I replaced the one on my '12 with the red one from the Viper & SRT
Part #: 1UL96XR4AA
I think it was ~$45
#8
May 18, 2016
I've actually been thinking about that swap. Was it straight plug/play?
0
#11
May 21, 2016
(Edited)
Wonder how well it would work to spray some clearcoat over the switch and bezel before reinstalling, to help prevent wear by directly touching the lettering. I'd think it would take longer than 5 years for that much wear to develop.
#12
May 25, 2016
I did the Red button replacement on mine as well. Not very hard, and I found some online directions.
I believe I still have my stock one. Essentially new (less than 5K miles) if you don't want to invest in a truly new one.
#13
May 25, 2016
Can you find them again and post?
0
#16
May 27, 2016
That ad says 1UL96XR4AA under item specs then B in the description. Probably a typo but should be the same one.
Ha I noticed they use my pic. That was my car..
0
#17
May 31, 2016
Thanks Sal,
I ordered from them actually, but that's funny they used your car picture, even if it is thievery!
