Blacktop rims with 245/45/20 Firestone tires and TPMS.
Well I dropped the bomb yesterday, that I sold my car. I traded it for a Grand Cherokee Overland. When I did, I took off my louvers, and rims/tires, knowing the dealer wasn't going to give me any extra for them.
So here they are. This is just a "quick" post to get it out there, and I'll update later (hopefully tonight) with a lot more detail and pictures.
The rims and tires are nearly new. I bought them last fall (fall '15) and stored the car all winter on the stockers. I've only had these on the car for about 2 months worth of use. The car was a bit over 2 years old, with 8,700 miles on it (yes under 9K, that's not a typo). So I estimate they've probably got less than 500 miles on them. I don't expect new price for them, just pointing out that they're nearly new.
The tires are Firestone Firehawk Wide Oval Indy in 245/45/20. The manufacture date of the tires is 3415 (I'll attach a photo later). That's the 34th week of 2015, which is some time between August 17-23.
The rims are replica Blactop rims. I originally bought a set of used Blacktop rims. The condition was pretty rough, and I cleaned them up and used them a bit. After a short time I decided I wanted NEW rims, so I sold those and bought these. These replicas were much cheaper to buy than OEM so I went that route. They look, and fit identical to the OEM rims I had except one thing. The lug holes are smaller on these, so the stock lug nuts will not fit. To mount them, I simply bought spline drive nuts. This is common on aftermarket rims, and even the Mickey Thompson rims on my Ram have the same lug nuts. The lug nuts needed are included with the rims and tires.
Additionally these do have TPMS (tire pressure sensors) installed. They synced to my '14 without having to "program" them. Any Charger/Challenger using the same frequency sensors should be ready to go with them.
And obviously they are still balanced. I had no reason to take the balancing weights off, or dismount the tires from the rims so they'll still run smooth.
I'm looking for a local sale, but I'll ship if you cover the shipping cost. As noted, I have a Ram, so if you're somewhat close I can meet you somewhere. Same deal for the louvers.
Shipping will probably be crazy expensive, so I suspect local pick up will be the way to go on these, but I'll work with you if I can. The louvers were custom fit (by me) to work on the '11-'14. They will include mounting plates, which I'll put new tape on.
Blacktop replica rims, Firestone Firehawk Wide Oval Indy tires, TPMS and complete set of lug nuts (with key): SOLD
Louvers with mounting plates: SOLD and removed from title.
Edit 6/3/16: Both items are now sold
