Many people are asking for a special so we want to support that again as a vendor. We have been a vendor now for 8 years and counting!
We continue to do a lot of Hellcat cars (which only take 6 quarts of oil with filter by the way and 7 quarts on the 2017 6.2L) and people looking for more performance, we added the Hellcat for both the Challenger and the Charger. Hellcat Charger/Challenger oil is 7.5w40 Ultra High Performance Racing Formula Engine Oil and QuantumBlue Ultra High Performance High Flow (11 gpm) Oil Filter (#3)
1) ACES IV Special: 1 gallon ACES IV Treats 770 Gallons of fuel @ $244.95 - Regularly $279.95 - (Save $35.00). 1 Liter ACES IV treats 200 gallons of fuel @ $69.99 - Regularly $85.00 - (Save $15.01).
1a) ACES IV 2.5 gallon container - Treats 1925 gallons $596.00. (Save 103.88) Comes in an industrial container. People had been asking for a bulk size ACES IV a long time and so we did it for those who now wanted it!
2) Performance Special: 1 Liter ACES IV, 2 gallons QuantumBlue Custom Blended oil for any car, and get one QuantumBlue Ultra High Performance High Flow (11 gpm) Oil Filter FREE for - $173.55 + Shipping. Normally $212.95. (Save $39.40). (QB Long Filter for 2007 and before an additional $4.95.)
3) 6.2L Supercharged Hellcat 7.5w40 Ultra High Performance Racing Formula Engine Oil and 6.4L Hemi Special: 2 gallons QuantumBlue 7.5w40 Ultra High Performance Racing Formula Engine Oil 6.4L Hemi MDS Custom Blend + one FREE QuantumBlue Ultra HP High Flow oil filter - $103.60 + shipping. Use 6 to 7 quarts for the change and two or 1 qt left for top off- Hellcat and 7 qt + 1 qt for top off 6.4L Hemi! (Save $29.02). Manual cars same price but different viscosity.
4) 3.6L DOHC 4 Valve Special: 2 gallons of QuantumBlue 7.5w27 HP Competition Formula Engine Oil + one FREE cartridge filter and gasket - $103.60 + Shipping. Use 6 quarts of the oil and have 2 quarts for top off if needed. Then if you don't use the 2, order 1 gallon next change. (Save $29.02). We do have the 2014 and up filters too so no worries on the new cars as well. It has the centering cage and more pleats for filtering the new volumes.
5) Oil special 2 gallons QuantumBlue Custom Blended oil for any car, and get one QuantumBlue Ultra High Performance High Flow oil Filter FREE for - $103.60 + Shipping. (Save $29.02).
6) Winter/Spring Coolant Flush special: 2 gallons QuantumBlue HP Gold Concentrated coolant $72.98. 6 years-150,000 miles between changes. -45 deg F to 286+ boil over at 15 psi. No sodium or silicate problems like OEM coolants. IAT, OAT, and HOAT compatible. (Save $12.98) and FREE SHIPPING THIS MONTH!!
7) Steering System Protection Special :Two Quarts QuantumBlue LX/LC Steering System Fluid/Flush + one 4 oz bottle of QuantumBlue Steering System Lubricant Catalyst - $39.95. Stop that whining and moaning sound from your steering system pump. Protect the rack and seals. (Save $5.48).
2011 and up cars use the QuantumBlue EHPS Electro Hydraulic Steering System Custom Blend. $22.80. Comes in 1 pint replacement squeeze bottle with cone cap applicator. (Save $7.19)
8) Hemi/3.5L Transmission Pan Drain and Fill Special: 8 quarts QuantumBlue transmission fluid appropriate for 42RLE and NAG1/W5A580 transmission + QuantumBlue Transmission Filter Kit - 42RLE-$133.57 (Save $16.95) and NAG1-$149.99 (Save $38.92)
9) Differential Protection Special: QuantumBlue 75w125 Differential Fluid Custom Blend @ $51.80 per 1 gallon. LSD Differentials use 85w100 and 85w110 and six speeds are 85w100 or 85w110 which are the same price. Works for LX, LA, LC, LD and WK Applications (Rear only on WK....75w90 Front differential...same price) (Save $9.76)
10) 8 Speed transmission Flush Special - 8HP45 Transmission only 2012 cars have this transmission. 8 quarts of QuantumBlue ZF 8 speed Custom Blend transmission Fluid - Replaces Mopar P/N 68157995AA and P/N 68142478AB. Includes the plastic transmission pan/filter combination. $364.20. (Save $179.14) includes filtran pan and 8 quarts of fluid - No fill tube on this trans. Check via plug on side of transmission. The 2013 and up cars are using an 845RE 8 speed transmssion. So $ 301.20 (Save $135.30) for the pan/filter assembly and 8 quarts of ZF 8 speed Custom Blend Transmission Fluid. The 6.4L Hemi and the 5.7L Hemi both take the 8HP70 while the Hellcat takes the 8HP90. We use the vin to make sure which pan is correct for each application.
11) Interior Prep for Cleaning,Protecting and Storage Special: 1 quart QuantumBlue Vinyl and Leather Protector, One quart QuantumBlue Vinyl and Leather Cleaner $29.95. (Save $6.22)
12) One Quart QuantumBlue Anti-Corrosion Metal Dry Lubricant Spray - $24.29. Designed for the engine compartment to prevent corrosion - which is the white powdery corrosion on heads(V8 and V6) and engine blocks of the (V6). Great anti-conductive spray to keep water, salt and corrosion out of wires. Safe on all plastics. Great to keep all the corrosion off the engine and the wiring during Winter! (Save $9.50)
13) Make your own special. Anything you would like to see or combine we will do it for you!!
All orders get appropriate decals included!
Also, looking forward to talking to our present customers who want to purchase more and welcome to any new ones as well!:beerchug:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
Regards,
Brian
440-821-9040
