Originally Posted by danaM
I did forget to mention that I had the dealership fix a rattle in the dash. Well, it is not really fixed but it is not as annoying as it use to be.
No leaks and the level is fine.
I pulled the codes and this is what I have:
P 0520:
Engine Oil Pressure Sensor Circuit.
B 1668
Reverse Lane Control Circuit High
Maybe it is the switch after all.
D a n a
Ya those are both circuit codes. I cant see how someone jacked up that sensor based on its location but maybe they did. Maybe they got happy putting the filter on. that code is pretty simple diagnostics. its either the three wires going to the sensor from the pcm, the pcm , or the sensor.
the 1668 is a circuit failure on your reverse light circuit. You got some wiring issues you need to get handled.
Originally Posted by Crow
Damn it wicked, my oil pressure never hits 30 psi at idle (at normal operating temps).
Either my pump is jacked or... are you sure about that 30 psi at idle??
I'm sort of worried.
I've never seen less than 30, come to think of it i've never seen less than 40. I start the car and it ramps up to low 40's and runs as high as 60ish on the highway. (cant remember highway as much as thats a rarity for my car).
More opinions? Anyone else running lower than 30 at idle (cold/hot)?
