Killerglass Install HELP! - Dodge Charger Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
  #1
Old 03-03-2012, 07:01 AM
Dlucchese's Avatar
Dlucchese Dlucchese is offline
So to start, I am not mechanically inclined what-so-ever. I just got in my Killerglass and thought I have seen a lot of threads on here of the finished product, I can't seem to find any that walk you through the install itself. The biggest thing I need to figure out is how to drain the existing fluid. It is going into an 06 R/T. If anyone can help I would greatly appreciate it!
2006 Brilliant Black R/T - Borla Cat-Back Exhaust | K&N CAI | Custom Predator Tune | 20" Viper Reps | KillerGlass | Billet Tech Everything | Oracle Lighting | Custom LED Lighting
  #2
Old 03-03-2012, 09:32 PM
Dlucchese's Avatar
Evening bump, anyone know how to drain existing RAD fluid?
  #3
Old 03-03-2012, 10:44 PM
lowriderman3's Avatar
lowriderman3 lowriderman3 is offline
Supporting Member
My Charger: 2011 R/T Plus
^^Bump to get you some help brother. Sorry I could not assist as I had mine installed by my friend as it was bad weather that weekend.
"They Were Just Jealous That My Charger Pulled More Kitties Than A Bowl Of Milk"
  #4
Old 03-04-2012, 01:15 PM
funkpolice6's Avatar
funkpolice6 funkpolice6 is offline
My Charger: [IMG]http://i305.photobucket.com/albums/nn201/funkpolice/166cd1f5.jpg[/IMG]
I don't know about rt, but my srt has a petcock on the lower passenger corner of the radiator. pull the passenger front wheel. open the petcock (180 degrees counterclockwise and pull out) be carefull, it's plastic. open bleeder screw. mine was on water pump. let coolant out. pull upper radiator hose. I had my fans out at this point, don't know if you would need them out or not. install killer glass pc. close petcock, but leave the bleeder open when you refill coolant. I've heard putting the coolant in at the water neck will introduce less air into the system.
bill
07 BB SRT8 Charger
Tuned by Tim@ MPH-402 RWHP, SRT max plus camshaft,3.73 Getrag LSD,Magnaflow Catback,D1s HID conversion,Removed moldings and badges.,diablosport,predator,180 thermostat,tranZformer,Airaid Cai,BT Catch Can and underhood stuff, Interior red led color swap
  #5
Old 03-04-2012, 02:58 PM
Dlucchese's Avatar
I got the rad fluid drained and the glass in, I refilled the coolant in the tank, let the car run for about 10 mins to come up to temp and never saw a lick of fluid come through the glass. Did it a few more times and then opened the petcock and let it drain again to see if it would come through the glass and it did not. Am I missing something?
  #6
Old 03-05-2012, 10:51 AM
rodneyiii's Avatar
rodneyiii rodneyiii is offline
It sounds like there is still lots of air in the system or the T-stat hadn't opened. Did you leave the bleeder plug out when re-filling the system?
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
  #7
Old 03-05-2012, 11:10 AM
Dlucchese's Avatar
I got it corrected and running properly last night, thanks guys for your help though, much appreciated. Now if Killerglass will put a rush on replacing the LED's they sent in the wrong color, I'd be golden.
  #8
Old 03-05-2012, 03:56 PM
Supporting Member
^^Great to hear!!
  #9
Old 03-05-2012, 08:11 PM
rodneyiii's Avatar
Post some pics when you get it finished.
  #10
Old 03-05-2012, 08:29 PM
Alfisto's Avatar
Alfisto Alfisto is offline
Lifetime Supporting Member
What color are you going for? Reactor Fluid Green? That would be too cool
2008 Steel Blue Metallic Charger R/T "Baby".
Tinted windows, R1 Concepts drilled and slotted rotors, Russell s/s brake lines, red HEMI overlays, Predator 91CAI tune, body colored washer nozzles, Mopar 11 shifter, honeycomb grill, red R/T logos, 6000K HIDs lows and fogs,Pioneer AVIC-X930BT, JL Audio PowerWedge 12" subwoofer, AFE Stage II CAI, hood struts,Super 44's with ZOOMERS Cannon tips.
You may not post new threads
You may not post replies
Need help with killerglass install MzGudz Charger Problems/Assistance 0 09-08-2010 07:05 AM
Brand New KILLERGLASS RACE TUBE Daytona #3223 Parts For Sale/Wanted 35 04-03-2010 07:47 AM
Charger + Killerglass = ???? Ezcorpion Interior Discussion/Modifications 23 12-03-2009 11:48 PM
Killerglass and BND Gold EVIL R/T General Charger Discussion 3 09-05-2009 06:52 PM
Killerglass Radiator Hose BENISASPUD Exterior Discussion/Modifications 26 03-16-2009 05:41 AM
© AutoGuide
